Irfp260 is better than irfp250.... 260 have low Qg and support more current.... why you don't use that?
Inviato dal mio Z00D utilizzando Tapatalk
IRFP250 from Harris Semiconductors..
what load did you test with the irfp250 at that voltage and the switching frequency , also how long did the amp play .
Hi stewin,
My AUD600 still running on theater as a sub woofer, connected load 2 x 8R(650W) 18" parallel
supply rail +/-87V (90V) tested on idle full drive +/-82V (900W RMS)MOSFET Used IRFP250 Filter 33uH T157-2 both are running cool
MANOJ
Hi stewin,
MANOJ
wow very very impressive sir 😎😎😎
hi all i have used ucd schema 400khz with irfb4227 one pair at +/-85vlts smps at 2ohms and all was o.k i wanted to use+/-110vlts can irfb 4229 handle that voltage??? please help
i have mmbt 5401/5551 and mmbt3904/4403 which ones can i use as gate drive to drive two pairs of irfb4229?????
Hello pantinjin
greetings do you sell high power dclass sub woofer amp modules
2000 watt power output
warm regards
Andrew
warm regards
Andrew
Hello pantinjin
warm regards
Andrew
Hello pantinjin
warm regards
Andrew
please post pictures of the amps modules you are selling , your website page is not opening properly.
😱 any advice or comment any one 😕😕
I don't recommend any of these, they are weak. BC807/817 are better, and FMMT549 is very good. (NPN can be weaker.)
Yes, BC807/817 or FMMT549's current is larger, and the driving power is greater.
TingjinPan
Ptj.123@hotmail.com
Https://shop129732915.taobao.com/
thanks guys , i wish i can get where to buy them 😡😕.
any way are there any to92 good gate drivers??😕
😎nice modules pantinjm how much do they cost in us dollars smps and amp module
that amp is hot . with the right power supply that is 5kwts rms at 8ohms and 10kwts rms at 4ohms.
Yorkville sub amp
Can i get rest of circuiit / schematic ?
Greetings
Hi DC Sound,my IRS900... sounds very awesome... good bass response
Do you have schematic of your irs900 look interesting to try to make my own one.
thanks
santosjoj
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
