I read a theory once that the fuse element inside a glass fuse can vibrate and resonate to the music adding distortion to the AC supply, whereas the sand filled fuses damp out any vibration 🙂
Love it !!
Whereas I prefer mass for damping.
How does mass damp? I see that phrase used often, but it has never made sense to me.
se
The directional fuses mentioned by Sy earlier...
isoclean
The ones I saw were a different brand (oh jeez, there's more than one guy out there peddling directional fuses!). I don't remember the company name, but they actually had a diode symbol printed on the fuse.
se
Pedant...
I pray for less vibration....
I prefer high mass (i.e. heavy objects, shelves lead etc.) for damping, if possible with a energy absorbing viscoelastic layer between two high mass layers.
Because the heavier the object the less it is likely to vibrate in collusion with the energy I am pumping into the room with my speakers etc.
Better🙂
"HiFi Tuning This German company has spent an unbelievable amount of time and money to ensure that you can get everything your system is capable of delivering"
Yep, sure ...😱
These, HiFi tuning
Hi FI Tuning 20mm x 5mm Internal Fuses (F) Gold
Yep, sure ...😱
Yep, sure ...😱
And at the bottom of the page is a link for "Phonosophie Pure Silver Internal 20mm x 5mm T Fuse" and "Consider this an ESSENTIAL upgrade!"
Let's see...$88.53 each...It will cost me only $531.18 to "upgrade" my Bi-amped system! I'm going to RUN and get my credit card!
Mike
Quantum fuses for UK mains plugs, a snip at £60 from the same seller:
Synergistic Research 'SR Red' Reference UK Plug Fuse
Pedant...
Pedant? Nonsense. "Mass damping" is a complete oxymoron. If it's pedantry to point out a complete contradiction of terms, then God help us.
Instead of praying, you should perhaps learn a little something about the subject.
I prefer high mass (i.e. heavy objects, shelves lead etc.) for damping...
Mass does not damp. Mass and damping are a contradiction.
...if possible with a energy absorbing viscoelastic layer between two high mass layers.
And it's that energy absorbing viscoelastic layer that is the damping, not the mass. Damping is loss. Mass, in itself, is not loss. Mass is mass.
Take a given mass, suspend it from a spring of a given stiffness. Stretch or compress the spring and let it go and the mass and spring combination will oscillate at a given frequency, depending on the mass and the stiffness of the spring.
Increase the stiffness of the spring and/or reduce the amount of mass, and it will oscillate at a higher frequency. Reduce the stiffness of the spring and/or increase the amount of mass and it will oscillate at a lower frequency.
If there is no loss in the system, it will oscillate forever. Add some loss, say by adding something that converts some of that stored energy into heat, and you have damping. The more loss you add (more damping), the shorter the period of time it will oscillate.
This is basic physics, not rocket science. They teach this stuff (or used to anyway) in junior high and high school here.
I'm not being a pedant here. I'm pointing out a complete contradiction of terms.
se
"Treated with over 2,000,000 volts of electricity!"
I tested one of this company's gadgets for headphones. It had all the efficacy of a Bybee. $300. I really wish I could lose the integrity that holds me back from scamming the suckers.
I know right. I should have really launched my fake cable treatment product i posted years back on this forum. I called it Cable-Op (an anagram for placebo). I was basically going to sell people glue and tell them it filtered out some pseudo scientific bs like filter out dark energy or matter.
It was funny one guy responded saying (paraphrasing) "On this forum i can't tell if he is joking or not"
I sort of wanted to open two companies - one with real innovations or products that will actually do something and one with snake oil and just watch how the snake oil company made more money over the years and compare the two at like the end of a decade.
and he has a cable library! Looking at that guy he is either a great actor or really does believe the s*** he peddles!
Sounds like he's on DRUGS, NOT ONLY can the gold help but it fills in the smooth ness of the tweeter !! WTF !
Did you see the video of his listening room ? He has negative air pressure pieces in the corners of his room that remove bad pressure at 37hz 🙁 FML !!
All i heard was every word echo in the room LOL !!
Sorry for the late reply - but solid core can make a big difference in video. Like make or break. Audio? That's another story.It even had a solid core in the coax and everyone knows that improves audio.
se
Nice to see you are still on form....
OK I agree the term is/was miss used.
I think you mean 'correct impedance cable can make a difference'?
- Member Areas
- The Lounge
- Funniest snake oil theories
