Yeah, i don't think he is a snake oil salesmen so i guess it was wrong to bring him up. Just a lot of placebo tweaking i guess.
But it sort of drives me nuts that a professional would recommend that your entire studio should float or you aren't getting optimal sound quality.
Whereas I prefer mass for damping. And in many older English houses, they have removed the chimney stack so you have a solid concrete area about 5' x 2' decoupled from the rest of the floor. Don't know how much difference it made but I had my kit on this, on a solid rack (thick glass shelves), but it felt right so I did it (looked cool as well).
Nah an open fire improves the listening experience
Nutty slack when I were a lad tha 'nows...
Lead water pipes and a tin bath and an outside bog, dragged up in a weavers cottage (worked donw't pit... from 18 months old part time)
Possibly explains a lot
My fireplace is supercharged by 120mm fans on opposite sides.
To quote Alan Ford as Brick Top : goes through 2 pounds of uncooked flesh per minute.
Sounds like a jet fighter taking off in the max setting though.
imo, ones entire home should float, but that's a different story. I make do with a 2'' wooden floor on rubber layered beams, 8 inches of rockwool in floor/ceiling and all-side Hawaphon. (1000+ sqft of the latter may not be everyone's cup of tea)
easy to tell when the fuse goes
semtex easier to mold better damping and far better transients with a slower release but more dynamic.black powder filled fuses - super fast - great transients
And it's the best bang for the buck!
D
Deleted member 24284
For Tchaikovsky's 1812 overture.And it's the best bang for the buck!
This theory wasn't on the Russ Andrews site perchance?
Ah no. Russ Andrews 5A SuperFuse™ : information Russ Andrews 5A SuperFuse™ ... his are silver, treated with Deoxit and £25!
sand filled silver element fuses have been used in high voltage lighting for 40 years plus bussman ktk series . conrad-johnson used those for plate fuses 30 years ago rated at 600 volt ac. These are just different physical sized fuses . And way up in price.This theory wasn't on the Russ Andrews site perchance?
- Member Areas
- The Lounge
- Funniest snake oil theories
