I think lifting cables pleases another sensor organ that we have, not ears, but eyes.
I can deal with that, it could be considered art vs rip-off.
Yeah, i don't think he is a snake oil salesmen so i guess it was wrong to bring him up. Just a lot of placebo tweaking i guess.
But it sort of drives me nuts that a professional would recommend that your entire studio should float or you aren't getting optimal sound quality.
Whereas I prefer mass for damping. And in many older English houses, they have removed the chimney stack so you have a solid concrete area about 5' x 2' decoupled from the rest of the floor. Don't know how much difference it made but I had my kit on this, on a solid rack (thick glass shelves), but it felt right so I did it (looked cool as well).
I heard LInkwitz once say that the only way he knew how to make a bass trap that would actually work was to have a wall of flames around the listening area 😛
But i think that's no BS
Nah an open fire improves the listening experience 🙂
Nutty slack when I were a lad tha 'nows...
Lead water pipes and a tin bath and an outside bog, dragged up in a weavers cottage (worked donw't pit... from 18 months old part time)
Possibly explains a lot😀
2003-2009 my house was heated by a rayburn. Got very well aquainted with nutty slack🙂 Not a fan of central heating.
My fireplace is supercharged by 120mm fans on opposite sides.
To quote Alan Ford as Brick Top : goes through 2 pounds of uncooked flesh per minute.
Sounds like a jet fighter taking off in the max setting though.
imo, ones entire home should float, but that's a different story. I make do with a 2'' wooden floor on rubber layered beams, 8 inches of rockwool in floor/ceiling and all-side Hawaphon. (1000+ sqft of the latter may not be everyone's cup of tea)
easy to tell when the fuse goes
semtex easier to mold better damping and far better transients with a slower release but more dynamic.black powder filled fuses - super fast - great transients 😎
And it's the best bang for the buck!
I read a theory once that the fuse element inside a glass fuse can vibrate and resonate to the music adding distortion to the AC supply, whereas the sand filled fuses damp out any vibration 🙂
D
Deleted member 24284
For Tchaikovsky's 1812 overture.And it's the best bang for the buck!
This theory wasn't on the Russ Andrews site perchance?
Ah no. Russ Andrews 5A SuperFuse™ : information Russ Andrews 5A SuperFuse™ ... his are silver, treated with Deoxit and £25!
sand filled silver element fuses have been used in high voltage lighting for 40 years plus bussman ktk series . conrad-johnson used those for plate fuses 30 years ago rated at 600 volt ac. These are just different physical sized fuses . And way up in price.This theory wasn't on the Russ Andrews site perchance?
There were folks at Axpona selling directional fuses for hundreds of dollars. Hilarious and sad all at once.
Bussman spec sheet doesn't actually list the element material. Does silver have a better melt property than copper?
- Member Areas
- The Lounge
- Funniest snake oil theories
