Sony vFET Amplifier Part 2
@ Luke
If this is your preference you need 2 pairs B grade LS jfets 8 mA Idss
for front end of this original Push - pull Part 2 amp see on schematic.
Jfets are out of stock today but they be back just hang around every day for :lickface:
Attention little more advanced level project if compare with Vfet Part 1 CSX
or others diy Mr Pass amp's designs.
Matched JFET pairs (Grade B) - Parts
Kind regards
Yes I know, but fortunately I bought a few of these already so its not a problem. TO3 package is a bit hard to work with but apart from that I'm looking forward to my next Pass amp.
I have a few questions, if 8ma IDSS Jfets are not available, can we use source resistors on them like we did for the F6? I see getting 8ma pairs kind of difficult at this point.
The next question is, for the bipolars in front end, It looks like Nelson may have been using a ZTX 450,550, but I am wondering if 2SA1837 and 2SC4793 like is used in the F5Turbo. Forgive me if this has been discussed previously.
I received 4x 2SK82 from Aliexpress.com : Buy SONY 2SK82 V FET from Reliable fet transistors suppliers on Eternal HONG's store | Alibaba Group today. I was initially skeptical due to the different packaging however they look genuine and measure less than 2 ohms source to drain. I will build frankentracer to check curves. The only thing is vendors photo shows KE-33 parts but these are JA-33 so i'm not sure whether these will work with SJ KF-33.
Hi Fatfreddy, how will deal with any mismatches? Your sample group is quie small so its possible you wont get good matches.
We're working on getting a lot more. We're brewing up a bigger batch for next month!
@ Luke
Kind regards
How did it became a Bad Part? Is JA-33 in the market now considered OK?
I'm not knowledgaeble enough to tell if JA-33 is considered OK, but I was helping some brave souls to order a few of these, so I tested them one by one before taking them to the post office and one 2SJ28 happens to be bad.
Something I can tell from the dozens that I measured:
  • They do display the triode curves of VFETs, I tend to believe they're genuine Sony VFETs.
  • As far as I can tell, the JAs are more linear than the KEs and KFs, but they have lower transconductance at the same time.
  • With the lower transconductance, I suspected they might be re-badged 2SK60/SJ18. So I drilled open the bad one, but the chip inside seems to be a 4mm chip, so they're not 2SK60/SJ18 which have 3mm chip.
Thanks and regards.
Hello all. I had got a lot of curves (KE, KF and KD types) and I have not find difference between them (types). Variability is big.
If JA type show typical curves, I think they will be good (always looking only curves). But until I receive them, measure and compare I could not be sure they are good (sure they are, Tim does a good job, thanks a lot, Tim). I think letters (KE, KF, KD, JA, ...) are batch productions (I can be wrong).
N type are better (curves) than p types, variability is lower. Look curves.
When I did the same with tokins (180, 182, 183 and THF51), we got a bigger variability than sony types.
I remember to have seen a picture of an open 2SJ28 which had two dies, and Nelson commented something like that they are possibly 2 x 2SJ18 dies in one 2SJ28,
So maybe these are rebatched 2sj18/2sk60?
Somebody have to measure them, and post curves or data to compare with real deal Acronmans.
All of the parts I got from Acronman are dual die.
See my Lab Hangout here, where we looked at them under a microscope:
https://youtu.be/dTqaR5qsT_0?t=19m30s
Try not to be overly paranoid about counterfeits, guys. Most of the counterfeitts I've gotten are pretty obvious, and no one is going to great lengths to make a part "act" like a triode. It's a SIT, or it isn't. Just be smart about your purchases and don't try to scoop up a bunch of expensive parts from an unproven source.
When I purchased the JA-33 parts my only basis was Visual Inspection of the marking. Under 30X to 50X microscope,
no signs of rework and marking is still original.
During Version 1, I happened to inquire these parts and it cost about 200RMB per piece.
Now the release of V2, since nobody have interest during the V1 period, I was amazed it was sold at 200RMB a pair.
In a period of 2 weeks, the sales has gone up, upon my purchased, after 5 minutes the price raised to 300RMB per pair
including other V-FETS model (YAMAHA and SONY).
Hopefully somebody can final confirm the authenticity of JA-33 which still have a big volume of stocks existing.
And Im sure Papa will be very happy to see many VFETS amplifier displaying on the Picture Gallery🙂🙂.
Cheers.
