900W Class H Power Amplifier
Yes, I compared it to the first version 🙂 I did a lot of work, to integrate the protection to the amplifier board....
Sajti
That's exactly what I did from the beginning, but it turned out more convenient to have amplifiers and protection on separate boards. Mainly because he forgot to place the triac protection, and management of air had somewhere to go, and it will control a single fan on the heated channel.
Understood Your idea, but I want to do it in different way: Put together everything, which are important for the sound, but not make worse sound:
Main pcb:
- input stage
-power amplifier
-protection relay+relay drivers+protection
-clip detector+limiter
Psu pcb:
- rectifier
- capacitors
- fan driver
- connectors (cabling between Main pcb and Display pcb)
Display pcb:
- LEDs+drivers
- inrush current limiter
I found this solution as a best to eliminate the spaghetti like cabling.
Sajti
Modulated rail version under simulation. The schematic, and the output waveforms.
Sajti
quick consult
hi all!.. Let me introduce to you; I am a new member in this wonderful forum. I am from Venezuela. I reply this thread because I will soon build my first Class H amplifier based on the RMX2450 of QSC. I congratulate the russian boy who created this thread; Good job!.. I hope you help me if required. I think it is not easy to build this kind of amplifier.. God bless you
hi waso .! i have failed to register in the russian vegelab forum .
i wanted to use irfz44 or irf1010 n channel mosfets only without complimentary . will this circuit work the one you posted using 3 steps using only tlo84??
  • forum.vegalab.ru  V.2013 storey PRO-amplifier in the class H pg 11 3 ?????.GIF
can replace lm339 directly without any modifications . on 3tier class h +/-45,90,135 in the above schematic ??
