Full Range Speaker Photo Gallery
No distortion from the crossover is actually what they say.Looks like an Alpair 10.3. Possibly in a sealed box with EQ. They don't take the recommended step to rebate the driver.
dave
Sealed?
So these openings under the drivers would be just for show?
An attempt at a desktop BL horn??
Btw, that looks like a MA CHR-70.3 not a CHP... and construction material is plywood and MDF.
AFAIK horns and small don't go well together... 🙂 maybe some one can run a sim?
I thought recognizing importance of phase was an interesting point as well as using a metal cone driver. Not sure how well it performs in reality.
We do know that the A10.3 performs really well. This is a smallish box for them thou, and i'd guess MDF.
$220 USD/pr for the drivers, and larger (13-17 litre), a well built plywood box (with a rebate) will likely get more out of them.
dave
That is more than interesting. Is this for a PA application? How do they sound?
Sound is loud, clear, fast, and very impressive.
The solid deep bass, with regard to the speakers of small diameter, precision and clean mid range, but I will do some for the frequency spectrum above 10kHz and have something to add to the linearization of the entire spectrum.
There's no any indication of micro/macro "reverb"-effect sound, and box is not critical of position to place in the room and the distance from the wall.
I have a small peak at the 800Hz feature (which must be solved by using an additional filter), and the continued decline of ~ 3-4dB / oct. above 10kHz (I'll add some super tweeter correction).
I left the possibility to combine different speakers connecting and get a different nominal impedance of the box (6, 24 and 96 Ohms) for connection to the OTL tube-amplifier (with an additional small transformer that will adapt the impedance of the future super-tweeter).
