100W Ultimate Fidelity Amplifier
Hello guys
I have an idea because I always have the problem where I can place the power supply board on the case, so I place a capacitor bank and RL on the PCB to see how it looks 🙂
those caps are 22,000uF 63V so far I like the idea what you guys think ?
Juan
Here is the data PDF and also drop in here Sprint 6 file in the same zip folder
Juan
A10
Very first design for the A10. Advice is very welcome.
Next is the detailed examination of the first layout and then we will make a prototype 😀
Regards Olaf
A10 First Layout
here is the first layout. I have found an error and corrected and etched the first PCB. For those who want to test it (Hi Terry 🙂), here are the Print Files.
Please note: No warranty! Not tested yet!
Hope, I will find the time this weekend to assemble the board.
Regards Olaf
Regards Olaf
Thanks Olaf,
Ready to populate. Wish me luck 😀
In trubble
Hi, I started testing.
Voltage is +- 25V DC. Input is shorted and connected to PGND.
Offset is constant around 5V DC.
Quiescent current is adjustable with Poti between 10 and 30 mA measured over the 22R in both rails.
I will change the 3k3 to 2k2. Any suggestions?
regards Olaf
