diyAB Amp The "Honey Badger" build thread
Solved it. On one of the channels q13 was soldered the wrong way. The other channel was fine, i just had to solder the test resistor.
It hasn't caught fire in hours now so I think the amp is finished. 🙂
I'm impressed how it compares to my sunfire 300x2. If I had to choose one of them to keep, I would stick with the Honey Badger 🙂
See , my patience paid off.
Wow , Q13. That one backwards would be the only one to make "toast"
of the whole output stage. No vbe = full current across the .22R's.
Of course - the sacrificial resistors burned (but , saved your butt).
Glad you got it.
OS
Seems like I messed up one of the channels. When listening to music I heard sparks from one of the output transistors. I measured 100v between the heat sink and v-
When I try to Ohm between the heat sink and v+, v- and gnd there's no shorts.
I measured 10k ohms between the heat sink and the metal tabs on Q16-18.
What is the minimum resistance I should have between heat sink and metal tabs?
After playing around with the mounting and increasing the resistance between heat sink and Q16-18 to ~500kohm I tried to apply the power again. Q16 started smoking and I shut off the power. Q16 wasn't laying flat on the heatsink, would that be enough to overheat in a few seconds?
After that I installed Q16 properly and powered up with the test resistors in place. They burned up in a few seconds. I suspect that I have damaged the output transistors.
How can I check if the transistors are good or bad? Can it be done when they are installed or do I have to desolder them first?
Was it the channel you had your first problems with (Q13) ?
Yes , not having one of the outputs tightened will cause it to quickly
overheat (1 second) because it will draw all the current (thermal runaway).
Usually the best practice with a output stage failure is to
replace the whole deal - drivers and outputs.
The "burnout" will stress all the others , making the likeliness of future failure
much greater. On top of that , a replacement won't be from the same group
as the originals , and may be different electrically.
Don't feel bad , I've done it. NJW's are @ 2$ each -cheap. A 12$ mistake,
but valuable lesson.
OS
Seems like Q16 released all it's magic smoke. I uninstalled it and put it in the transistor tester. That way I discovered that the tester enter self test when shorting all three legs.
I have uninstalled the boards on both channels and trimmed the edge on the transistor mounting holes with a 6mm drill to reduce the risk of short circuits. Also I ordered some thermal paste that has electrical resistance in it's specifications to use on both channels when I replace the transistors. I no longer trust Arctic Silver since they don't specify it's electrical resistance. I suspect that it might be slightly conductive after curing since the transistors was shorted to ground over night while the amplifier was switched off.
I want to thank you Ostripper developing this great amp and sharing it with the public. I have learned a lot from building it and now I learn even more when troubleshooting and repairing. This is so much more fun then buying an expensive amp off the shelves.
When the amplifier are finished and stable I want to build a pre-amplifier for it. There are so many different designs out there. Can you guys help me choose what type to build? I only need two analogue inputs and a remote volume control.
Arctic silver !!!! Whoa , this is not a PC. Arctic silver is conductive !
NO Arctic silver - BAD !!! (strait ZNO paste only)
PS - Kapton insulators need no grease ,or just a minute amount ... (best).
OS
Arctic Silver was what I had at hand from the years with overclocking and watercooling. I have allways thought that it was conductive.
When i was about to install the heat sinks and i realized that I didn't have any thermal paste except from AS. I googled it and read on AS' website that it was none conductive . I was a fool and trusted the marketing.
The Badger is alive! 🙂
OS
What's the best non-conductive paste to use sparingly with a semiconductor insulator, yet well sealed for thermal transfer? Is ZNO paste a commercial brand name, or should I just use Desitin? 😉
