SlewMaster Builds
Since i follow all slewmaster threads, i don't remember to see that anyone match his output transistors. Does anyone do it?
Marc
Only if you see one in a multi device setup that "hogs" Ic . Generally,
ON/Sanken bought in a group will be within .5mv across the emitter
resistors.
.22Re is pretty tolerant of slight mismatches. It is good to check every
Re after heavy use.
OS
I was surprised by the "across the board" stability of all my builds. But ,
I found it was the cap multiplier that kept the CFA's stable with the
30-40db isolation from that dirty ol' OPS.
Have you compared a IPS using a separately regulated supply? Possibly variable too, so you can adjust/determine what stage clips first, ips or ops.
Most do not like to do this added improvement because of? extra cost/complexity or of little/no benefit?
The IPS's always clip first. Most are cascoded. Thimios/still4given have
clipped them all. VERY tame ! Clip = rails - 5-6V (some soft clip with "rounded
edges"). Multiplier = -2V , Hawksford or Baxandall cascode = another - 3.2V.
Would we rather have the 5ma IPS enter into saturation (and be clamped) ,
or have that happen at the OPS ? We can better control how "dirty" the
clipping is at the VAS , as well.
This planned overload behavior will make an abused slewmaster literally
bulletproof - nothing is even remotely "strained". Most will actually clamp
and draw LESS current at a hard clip !
Edit - V1 and 2 can have a split IPS/OPS supply. Then I would recommend regulating
that supply to match the rails for that lower IPS voltage.
Edit 2 - With a separate IPS supply , even unregulated and fed to the multipliers -
almost dual mono PSRR would be had !! -90db+ is the worst with just one supply.
OS
2sc3503/2sa1381 replacement for Spooky IPS
Did anyone build the Spooky (or other) IPS using MJE340/MJE350 instead of 2sc3503/2sa1381 and compare the difference?
I'm unable to find proper 2sc3503/2sa1381, even Mouser stocks only KSC3503D and KSA1381E, which is not ideal either (I mean using different transistor grade in a pair).
Is the MJE340/MJE350 the only replacement for those?
And how much worse will the amp sound with the MJE pair?
mismatch madness.
In amps of old 😀 , the mismatch might of been a problem.
Cascoded VAS gain is determined by the to-92 (ksa/c 992/1845 or BC550/560)
active devices. A (slightly) mismatched cascode , no real issue.
With the cascode , even a MJE340 / KSA1381 pair would work !
Also , most IPS have both CCS adjustments and are servo'ed.
Non- symmetrical amps , like the wolverine .... you would get no performance
hit using a MJE(350) for the CCS half of the VAS.
The only amp that might be better with a closer matched pair is the Kypton V
(non-cascoded) .... but even here , the VAS gain is mostly determined by
the preceding stage.
A non-servo'ed classic "leach" amp with just a cap for DC feedback is
a "must match" topology to get acceptable offset and THD.
Slew IPS's are designed to compensate for the shortcomings of 21'st century sourcing.😀
OS
Thanks Terry,
I sent a PM to him, I hope the shipping cost would be acceptable. If not, I will try MJE340/350.
Stefan
No ... don't. Why not be smart. You have a "weaker" 3503 ,pair it with a
higher beta super pair (bc550/560) or ksc 1845.
The cascoded VAS plus the EF3 eliminate the 20'th century matching BS
-period !!
Even if you did not do this , it would surely beat a high Cob 340/350 setup.
PS - the 340/350 would work , but slew and bandwidth would suffer.
The primary input pair (or pairs) are much more important to at least get
close.
As are the beta's of your groups of P and N output devices , to keep any
one of them from "hogging" current.
Edit - the kypton ND (best of the CFA's) shows 1ppm change using a ksa1381/ toshiba 2sc4793 pair
as VAS cascode ! Thd DOES rise with a mismatched input pair , as predicted.
OS
Well, unfortunately I do not have enough knowledge to alter the design.
I must admit that I do not fully understand your advice.
My situation is that I'm unable to find either of the pair (KSC3503 and KSA1381). I did not find a suitable replacement, so I'm looking for a solution. Either find the exact transistors, or to understand the design better.
So you say that if I had the correct devices but different grades, I can compensate by using higher beta cascade member (let's say if Q13 is "weaker" than Q12, I can use higher beta device for Q14) (Speaking of Spooky)?
It makes sense, but anyway, I do not have either of them so it would be easier to find the correct devices. I did not buy the non/matching pair from Mouser, because the shipping cost is way to high for me.
Thanks for advice anyway, I learned a lot from you guys already!
Most of us don't completely understand what OS is saying.😀 You don't need to change any components to compensate for the mismatched gain ranks of the VAS transistors. OS took care of that when he designed it.
No , NO , you DON'T have to alter anything. When you are testing out
transistors .... just do a "controlled mismatch" on the VAS.
The gain of the cascoded VAS-hawksford ... is (active device + cascode) . So ,
offset the weaker 3503 or any other device (you could even use a
1837/4793 toshiba pair - reversed) in the VAS.
Just has to have a higher Ft and lower Cob - wide range will work.
Maybe a pix will show (below). SOOOOO simple a concept.
super-pair cascode is even more sensitive , just 10% more beta on
the weaker 3503 (for example) bc550/560's will counteract any imbalance.
You will end up with a perfect VAS , as good as a curve traced ,"anal"
matching. super -pair might not even matter .... just picoamps of
load on the input pair(s).
Edit - just save a few of your "oddball" higher gain 1845's to offset the 3503.
OS
