Pitchfork pre-amplifier
From your waveforms shown, zero crossing would be a good starting point as well.
The problem is the flux. Zero crossing point varies in time because the noise. So, the best is to liberate us from-it.
By example, we can use a FIFO and a clock as perfect as possible.
The process is to record the flux. Independently, read the first bit, then wait for the next edge of our low jitter clock to build the pulse.
I hope i'm clear enough to be understood even with people having no idea of the process.
There is a thread in diyaudio, where the op put together a low phase noise osc & had a group buy. The guy from Italy, selected Laptech as the crystal supplier. That rang a bell as it is a local supplier who we selected, to buy our crystals, for fibre optic comm systems we were designing.
Find attached the info from that thread.
Do you know of a distributor for Laptech crystals or is it manufacturer direct only?
I believe they are mfg direct, but the op of the ref thread said they had a min qty of 5-6 IIRC. Send them an email or phone them to find out.
Also as "Esperado" was explaining, "iancanada" has a thread on asynch FIFO for this application.
http://www.diyaudio.com/forums/digi...project-ultimate-weapon-fight-jitter-356.html
They're not far from here but the minimum quantity might turn into a problem. It would be nice to find something of similar quality that anyone could purchase easily.
I've checked out a few of Iancanadas threads. He's got lots going on.
I do not think you will be able hear nor measure this jitter concern, so I'd suggest pick a common xtal footprint or pattern in Diptrace terms and go with what is available at Mouser or Digi-key. Could offer a way to implement the FIFO idea as an option but I do not know enough of the details to offer solid advise.
I have not spent much time either following the asynch FIFO thread to understand the benefits and if they are apparent upon a listening review.
I'm thinking of just cranking out a quick tester DAC with minimal controls just to test with. I'd like to try to stay as simple as possible with good sounding results but I don't have enough experience with DACs to wing it.
I've ordered one of Linuxworks boards as a quick tester to see if the Arduino is up to the task too. If it's too clunky I'll need to step up to a better processor but I would really like to keep it simple. Is it a huge amount of coding to write firmware for select-able display screens and controls? Some may like encoders, others may like pots. Big screen or small. Options are nice.
Depends on a lot of things. What you want to do and what type of display that you use. I know that Linuxworks stuff is done with a Character LCD, so that is a lot easier than doing it with a graphics LCD such as FT800. A graphics display will have significant more amount of coding, meaning more flash space requirement.
Modifying Linuxwork code to fit new features, change the UI, is not an easy task, one that requires a huge investment in time and frustration. One that i would not think is a good path to follow for a rookie, due to the confusion and available support.
The display interface can be designed to operate both a std character and FT800 type graphics display, so that can be a h/w option.
Hard for me to give advise when i do not know the feature set of your design, how you want to operate the device, "UI" look and feel etc.
One thing I do know is that avr-xmega is cheaper/faster/more-mem,features than a regular avr-mega and has a much better upgrade path. But if you want to leverage someone elses code, then it is best to stick with the same architecture/device family.
I am playing around a bit with DipTrace. All these EDA tools have their own way of doing things for sure, but the libraries are massive. I did notice all the pattern libs only have a silk screen layer and no assy layer info. they think only one layer will do, it is near- sighted.
Did you get your bootloader figured out?
I haven't had much time to mess with the bootloader. It's loaded on a board but i need to load USB firmware before I can do anything with it.
Some of the Diptrace models have assembly files with them. The board house I use converts them to silkscreen and prints it on the boards.😕You can edit your own models and add assembly layers to top or bottom. You can copy the existing libraries to another folder and edit them as well.
Some of the Diptrace models have assembly files with them. The board house I use converts them to silkscreen and prints it on the boards.You can edit your own models and add assembly layers to top or bottom. You can copy the existing libraries to another folder and edit them as well.
Sure, I figured that much out so far and that is exactly what i did,copy to another lib and edit. It is just a first observation, that assy layer info are missing in most patterns & silkscreen layers info is there for most but it is not the same as assy layers, as I am used to using. Assy layer data is not required for pcb fab but is useful for design usage. It is a minor issue like I said.
I also see a dual RCA phono conn that you can use too, CUI RCJ-2123
which is the same as
161-4219-E Kobiconn | Mouser
Good Luck
Rick
I've added some heat sink to the regulator pass transistors and did a little testing. The regulator seems to be dead stable and quiet but the slew rate of the linestage itself isn't good. Sine waves turn to triangle waves around 40khz with no load. It's designed from this schematic. Should I be adding the extra diode in the output like the diagram in post 1?
On the schema you posted , raise R22/16 (the CCS's) to 270-330R. That
will cool things down. You want 50-100ma class A at the output stage.
Headphones or an amp input will never load down to 47R (like I anally tested
it at) - overkill by a wide margin. 50 ma would even drive the most hungry
headphones.
I might be wrong , but the much higher Z op-amp input could work
without such a big capacitor for the filter , try 22-47pF ... we just
want to filter any RF here.
OS
headphones.
OS
270R puts the output at 75mA.
