HermesBBB-Cronus-Opus
You are all set on the hermes - I tend to prefer to keep the male headers on the same sides - so I would put the put the male hermes pin headers on the bottom of the hermes and the female on the top of the Cronus.
Cheers!
Russ
just to make sure you want every header in Hermes, male and make Cronus a female.😉 no Gender identity crisis allowed....
The simplest and best way to to wire the Cronus to the opus will be to orient the digital output of the Cronus close to the digital input of the Opus - then just use short (1 or 2 inches if you can) hookup wire between the modules - one for GND,BCK,LRCK(D1 on Cronus), Data(D2) on cronus. You will then use it as you would any other source with Opus.
Cheers!
Russ
Hi Russ,
OPUS needs MCK input from Cronus. Where can I find the clock output on the board? Maybe the hole for mck near the output header?
I will also post this on the cronus thread - but here is the pinout of the .1" headers at the output side of the cronus.
Thank you, Russ. This scheme was of great help to locate the MCK output pin and now my dual mono Opus with volumite installed is working well with another set of BBB/hermes/cronus boards and botic driver, which was of course confirmed to work perfectly with B3SE. The sound is superb!
BTW, I found that H/W and S/W dividers are not working with Opus, as long as my current dac setting, though almost default, is concerned.
With 45/49 clocks set to J1:2, the MCK output on the scope remains the same. This is also the case with S/W divider by miero after editing kernel option.
Just wondering I might have missed something essential because it appears these settings were all bypassed. As of this writing, 22/24 clocks are on the Cronus.
Anyway, thanks for this comprehensive scheme.
Russ, I have the 49.15 MHz and 45.158 rhea boards. I guess there is no particular order to solder them? There is X1 and x2 marked on board.
Does the above post from Twluke means I need a different Rhea board for Opus to work with Cronus? I am concerned with playing 44.1kHz material without re sampling .
WM8741, aka Opus, supports the MCK only up to 33.86/36.86. So 45/49 is beyond the ranges. Plan B option hinted by Russ may work but he did not recommend it (probably due to the disruption of the time alignment integrity intended for Cronus).
Ok, that means I have to buy a new clock crystal. What type of crystal I should be searching for in mouser ? TTL , CMOS , HCMOS ?
Does it have to be a pair or just one crystal 22.579MHz for ( CD audio) only will work with Cronus ?
What does Rhea boards do other than converting Smd to DIp ?
22/24 Rhea boards from TPA are ready for your order. Don't waste your time.
Twluke do I need the pair or just 22.579 is all I need for 44.1khz to work. Also I am under the impression they are sold out in TPA and won't be available until May.
Check their page. You'll find the items are all available for ordering. In your case a 22.579 Rhea board will suffice your need. They say shipping begins in the week of May 4. Don't miss the train.
I think i made a mistake, I did not see the DIP sockets that came with Rhea so end up soldering the Rhea modules to Cronus. Now trying to de- solder them. It seems like it is not possible to take them off. I am stuck
Don't give up. Welcome to the world of DIYers. First learn how to de-solder by watching many of YouTube archives. There are a plenty of methods to desolder. Find the best way you think you can dare to manage. Good Luck.
