Live Lab Hangout #1.1 Posted
Hi Michael and Diyers.
Merci ça va très bien. Formidable 🙂
Very rare to see sit's Tokin big chips how they look like inside.
World premiere exposition in diy universe its a chance.
Mike you say good parts and good parts again this time its clearly optimistic about 182ES
and between 0 to 40 v they have some similar parameters of Pass SIT-1.
Woow sensational let´s look at for Tokins refurbished from fish finders 😉
Ok load lines in next Lab Hangout learning don't stop
Any comments on Tokin datasheet interesting points ?
and next question : what influence of turn on/off switching time in micro seconds ?
Dady's sit's THF 51 have very short 50 micro seconds and 180, 182 five times more.
Thanks again for such great work Michael.
Best regards to all Diy Audio Gentlemans.
Christophe
I guess, Christophe, my friend, that you have to build a lamp-amp with the 182. Make a 12volt DC easy variable-reliable source. Get some lamps, we got 500watt in 125volts, old incandescent lamps (look for in old electricity stores, they have from some time ago when the power was 125volts. Make a bench imitating the Michael one, with a piece of wood. A heater sink fixed with or without isolation from the transistor. Start with 12 volts in gate. 50 volt 2 amps power supply, better if you have a variac, its useful for plenty of works you going to make in the future. Start to burn your things, making mistakes by trial error you will learn. And a soon you have the lamp-amp working connect music to it.
Low impedance source. A french bird told me that you have high sensitive loudspeakers you going to find your sweet spot soon, or later but is a simple circuit but reliable. I am learning like you. I making the mine in these days while the master is showing his goods to us. Camon Soundhappy. We are waiting for your amps and watts news from Montpelier.
Much appreciated.
The capacitance measured in the video is the effective input capacitance, that is the capacitance you will actually need to deal with in a common source amp stage.
The Miller capacitance is equal to the Drain-Gate capacitance multiplied by the stage gain +1.
The input capacitance of the gain stage is: Cin = Cgs + Cgd*(A+1)
So, if Ggd is already large, say a few thousand pf, and the voltage gain is also large, the capacitance you'll be working with can get pretty big, then you start looking for your high frequencies. 🙂
Measuring the interelectrode capacitances directly is usually done with a capacitance bridge and it looks rather tedious, even for me. I don't bother with that, because I'm not generally concerned with the specifics, just the aggregate effect.
Did that help any?
What the heck, if you still want to spitball Ciss, then let's first assume that Cgd and Cgs are roughly symmetrical in these parts.
Then:
14,000 = X + X(5.6+1)
14,000 = 7.6X
1842 = X
So, Ciss is twice that or 3684pf. Of course, that and $5.00 won't get you a coffee at Starbuck's, and what really matters to fearless amp builders is the effective capacitance.
Did that help any?
Yup, big SIT chips just mean big capacitance at the input. I guess I am still justifying all the "small" 2SK180s I bought!🙂
Either way the capacitance doesn't really matter much to me. My buffer is strong. A little wiggle room on bandwidth is always nice though.
Edit:
My vote (if it counts for anything) is to skip straight to the top secret stuff!
-Greedy Boy
There's no need to justify your 180's, they're great parts. I just bought a few more myself. Of course the 180's aren't immune to Mr. Miller either, but they have lower intrinsic capacitance and less gain, so he doesn't have quite as much to say.
They all have their virtues. 🙂
P.S. soundhappy's datasheet says Ciss is 2500pf on the 182E. I could have saved myself the algebra. 🙂
@ Dady
Yes i was charmed by L'Amp 2SK180 song & bulbs glow.
Next thing like newbies do i was in entusiasm to try too many projects in parallel
for example last week i finalised F4, F5 and Aleph J
stuffing completly boards with components youpii is ready
so must think some psu's for this now.
CSX-1 Papa Sony are next , pcb´s wait on table with complementary vfets.
Btw last weekend i negociated anodise heat sinks in factory for Michael new Tokin amplifier i want diy.
Patience help a lot and step by step projects become real amplifiers and bring us joy in everyday life.
24 hours is to short.
Yes let's do it class A amplifiers with solid state triodes 🙄
Gracias Amigo Dady
Have a nice day 🙂
