No NFB line amp (GainWire mk2)
There is a difference between the schematic and the board layout in the input.
Resistor R29 (47k) is connected between gnd and Q11 Q12 bases.
So P1 from the pot only connects directly to R50 (1k) and not to R29.
it seems ok to me but am I right ?
I have static (DC) offset in the input.
I did not connect the 10k yet so I am measuring input offset at P1 (just before the 1k R50)
I read 11mV..... should I expect a reduction of this value when I connect the pot ?
IMO it is the Q11 Q12 base current flowing in the 47k to gnd, so paralleling the 10k pot should reduce the offset right ?
Yes you are correct. I changed that on the layout but forgot to do that on the schematic. This does not change anything functionally.
Attached is corrected schematic.
About TIM, i believe this filter is not critical when using no NFB. I should try the best value in careful listening when global feedback is used. It can change a lot the sound quality depending of the other components in your system, specially the power amps. Sometimes, drastic filtering gives the best results.
This a bit tricky, you should take in account the source impedance, and off course the power amp input LF filter. When you say drastic filtering, you don't thing that we have to go below 20kHz? And depends what the source is, analog or digital? Many variables here.
Indeed, dadod.
Well, my CFA power amp use Diamond input, now. Its LF filter is isolated between the two emitter followers. Set just enough to avoid overshoot on little signal square waves (MHz) while compensated for flat bandwidth with no peak at HF.
This gives-me the widest bandwidth i can hold without any fear to see signals faster than its slew rate creating TIM. Independant from the source impedance. And remove something that i don't like in the diamond... some kind of a "nervous" character ;-)
In my situation, i should do the same for the pre-amplifier.
Now, somewhere in the channel, as close as the source as possible, i like to try to decrease the upper frequency of the all system. It depends a lot of the speakers we use, the source's quality etc, tricky as you said.
I do-it by a careful listening, in a very subjective way. "Voicing" ;-)
Of course i don't think reducing 20KHz signals in levels. Phases are a concern too. But sometimes, it can help ?
I was never able to add a super tweeter to my speakers with natural results. It is a two ways, using spherical horns for the high-medium. It cuts somewhere near 16KHz. Any try to increase the bandwidth at the upper frequencies (even with my active filter) seems just to add distortions and false trebles.
