Live Lab Hangout #1.1 Posted
2SK182 ES Tokin in test 20 V / 2A 🙂
The same sit numbers order on photos only voltage change.
Greetings
border="1"
| class="tcat"| #
| class="tcat"| SIT 182 ES
batch nr
| class="tcat"| 12 V
| class="tcat"| max 2A
| class="tcat"| 20 V
||1||1Z2670 || 2,51 || 0,308 || 3,00|| 0,367
||2||1Z2671 || 2,34 || 0,286 || 2,77 || 0,338
||3||1Z2672|| 2,26 || 0,276|| 2,69|| 0,329
||4||1Z2673 || 2,42 || 0,296 || 2,87 || 0,351
||5||1Z2674 || 3,18 || 0,389|| 3,97|| 0,486
Does anyone have any "known good" 2SK182ES, or curves for them?
I'm thinking the two that I have are bad. Even the high voltage curves are just way out of whack.
I think they should look a lot more like the 2SK180.
I've seen a "bad" 2SK180 that has that same whacked-out character, so I'm wondering...
Hi again Michael and Diyers
Maybe we can ask gently via email Maxonic or Sibatech team people some more 182ES informations ?
Personaly i am to newbie for speak with him about datasheet and curves
could experienced ask in the name of DiyAudio sit's aficionados please ?
Maxonic email : ktinter@nifty.com
Other ways ?
SIT Amps from Japan - Mockingbird Distribution LLC
Anyway this is e-mail i have received from Sibatech .Inc
" Many thanks for your inquiry on Maxonic/ SIT to our website.
Although "2SK77B" is not available from Maxonic, "2SK-182ES" SIT is
possible instead by \19,500/piece (Plus shipping cost) (Left side round
shaped device on attached photo)
Thank you very much again for your kind attention in advance and we look
forward to your kind response, soon.
Yours Sincerely
Hiroshi Ishihara
Director
Sibatech,Inc.
No.1301,8-25-22
Higashisuna, Koto-ku,Tokyo
Japan 136-0074
TEL:813-3645-1646
FAX:813-3645-1948
E-mail: <hishihara@sibatech.co.jp>
URL:Sibatech, inc. High-quality Audio Equipment from Japan "
Have a nice day 🙂
Good work, Christophe
Finger in the wind says that's looking good for you 🙂
Making lots of assumptions, that's mu average = 3.5 ish
Can you take another set of readings at the 30V (or whatever the high range of your bench supply is)?
Also, do you measure a little voltage across the 1k resistor?
Could you share the link on where to get those from Japan.
I wish there was a link I could point you toward. I had to purchase 20 of them at auction through an intermediary. They have not arrived yet, but I am led to believe that they are unused, new in box with sequential serial numbers etc.
As far as I can tell the seller doesn't have more.
I made a Spice model out of your 2SK180 curves with your modeler some months ago….
But I suppose you did it already Mike…. 🙂
*2SK180
*GENERATED BY SIT MODELER @ AUDIOHOBBY.COM
*MODEL RANGE: 100V, 2A
.SUBCKT 2SK180 D G S ; Drain Gate Source
+ PARAMS: MU=16 X=1.8 K=0.225 N=1.72 VCT=0 RG=2MEG
B1 D S I=K*PWR(URAMP((V(G,S)+VCT)+(N*LN(V(D,S))+(V(D,S)/MU))),X)
*FOR MULTISIM COMMENT OUT ABOVE LINE (*) AND UNCOMMENT NEXT LINE
*B1 D S I=K*PWR(MAX((V(G,S)+VCT)+(N*LN(V(D,S))+(V(D,S)/MU)),0),X)
R1 G S {RG}
CGS G S 1500P
CGD G D 0P
CDS G S 0P
.ENDS 2SK180
