Shannon ad fc/2 tricks
Is not certain a place to write certain compliments but only a interchanging opinions in quiet moods
This is not an interchange of opinions. It is a pair of monologues. I don't think you read the posts of others.
And, surprise, technical facts are not 'opinion'- they are not up for negotiation.
As intelligent people we can expect that we are willing to learn from each other. If that is not the case, it gets frustrating.
Jan
Under Shannon-Nyquist's hypothesis, quantization process is lossless and transformation is biunique.
So each signal has one, and only one, equivalent discrete transform. And vice versa.
There's dualism between the two domains.
Shannon
Tra superarlo e capirlo però ce ne passa. 🙂
Il tuo errore è di base e te lo stanno dicendo in molti.
Per il resto ci sono i libri e una solida dimostrazione matematica che non lascia spazio ad interpretazione.
Inoltre in precedenza ti ho postato un video pratico, se non ti piace la teoria. 😉
Si ma io sto parlando di altro tipo di problema vai al post 49
e segui gli step
è il motivo per cui si fanno i covertitori nos a parer mio
The plot at post #49 isn't the sampled version of a 15kHz pure sinewave.
The correct plot is from #51 by peufeu.
In fact, sampling produces dots (with lines), not curves.
Example:
Your plot seems an AM modulation. 🙂
you have lost othres steps ...
Example:
Oh do you knew a discrete sinc ....
Follow all steps and conclusions
Example of code to show a 15kHz sinewave sampled at 44100Hz is:
Code:
t  = [ 0 : 1 : 40 ];           % Time Samples
f  = 15000;                       % Input Signal Frequency
fs = 44100;                    % Sampling Frequency
x = sin(2*pi*f/fs*t);        % Generate Sine Wave
figure(1);
stem(t,x,'r');                  % View the samples
figure(2);
stem(t*1/fs*1000,x,'r');  % View the samples
hold on;
plot(t*1/fs*1000,x);        % Plot Sine Wave
And the plot is:
Adjust that code for your purpose.
PS: as written, your code plots nothing
Without dots you must reduce scale (plot less samples):
Code:
fs = 44100; %44100Hz sampling frequency
f = 15000;
t = (0:50-1)/fs;
x = sin(2*pi*f*t);
plot(t,x)
And you got something simpler to view but more difficult to understand, because Octave auto-link samples and in reality ADCs don't do that:
In reality sampling is this:
The same code of previous post, without the last line.
Code:
figure(1);
figure(2);
hold on;
I think that the major problem those images is the scale for X in frequency domain 🙂
Code:
figure(1);
figure(2);
hold on;
And the plot is:
icrease t from 40 to 400
Code:
t  = [ 0 : 1 : 200 ];           % Time Samples
figure(1);
figure(2);
hold on;
So, where's the problem?
Are you afraid of points involution?
It's an optical illusion 😉
Real FFT of this signal is a line centered in +-n*fc (quantization become spectrum replication) with n from 1 to infinite.
To see all aliases, you must use a proper command to obtain proper X-axis values (negative too).
AHAHAHA you are fine person
Code:
figure(1);
figure(2);
hold on;
Optical illusion ?!? hey guy what is described trough the samples, the modulation results are two sine in opposition of phase on fft you cant see them -fd cancel +fd
but these only on ideal system adc or dac
