That's no cannabis
[QUOTE
What fascinated me personally was an effect I could never explain. A taped song from a quality LP was in all respects like the original, but somehow, the bass lines tended to be more forceful, better defined, almost palpable, so much so that no cartridge I ever tried could match. It was so with my older Uher tape deck, it was so with the Philips, and it was so with a reVox A and B series decks.
Jesus, I loved those years.[/QUOTE
Copy better than original? Mona Lisa copy with more vivid colours than original painting? Some sort of distortion reducing effect? Or useful coloration.
Head bumps.
I threw out the capsules that were filthy, two had chewing tobacco spit dried all over the grid.
Charming, thank you for sharing.
BTY your microphones may work at 150dB but I strongly recommend you keep your ears below 102dB.
You know me I'm the 90dB max guy and no bass to boot.
I have never had a system that did anything in the bottom 2 octaves. Can't say I have missed it.
That's no cannabis
Nah, the kids would recognise that and tell me off. Shame I didn't get a picture of the xmas catcus (Schlumbergera)in bloom as that is another cutting off a mother plant that may be older than me. But here is it in all its glory.
Better use of my time to upload that than argue modulation noise...
I really don't know, but my guess would be coloration. Subtle in every sense except on deep bass lines, where it was hardly subtle, more like towering. And yes, I did prefer the tape to the orginal LP track. It simply sounded better to me.
Head bumps = bass boost...the boost frequencies vary according to tape speed.Everything you wanted to know about tape - Magnetic Reference Laboratory
Home Page
IIRC, JC a few years ago had much to say about his detailed studies of this effect/problem.
Dan.
See my earlier post #59988.
Dan.
What intrigues me, is that material that to me is critical for understanding what matters, where, is incredibly hard to find. At one stage I got very interested in the matter of microphone distortion, should be easy to find "reference" material, I thought ... another, Haahhh!! Talk about house secrets - in the end it seemed to come down to: this mic came from a famous manufacturer, just accept that it's going to be excellent, don't worry your pretty head about unimportant stuff like distortion ...Pavel,
The loudspeaker distortion curves are interesting. The issue is how much is the microphones contribution.
Cable squashed at on side of the reel ?.Attached is a TDR of TV camera triaxial cable that was recently shipped to me. Any one willing to comment on what it shows?
Length is about 600' and impulse is .1uS. RG11 with an extra shield.
Dan.
And yet a single google query gives me this http://www.bksv.com/doc/083-80.pdf which shows how B&K recomment measuing non-linearity. I am sure if i tried harder there would be decade of stuff from them. After all they make test instruments not musical instruments...
Your plant could use water.
Deviations from flat are due to impedance changes or mismatch--- Z vs distance/time. Check with Tek or HP literature on how to cal., use and interpret the measurement.
Being the test equipment junky that I am, I have and use the TEK 7S12 plug-in with S6 and S52; A 25ps system. Not a current model... newer models exist....but works fine.
THx-RNMarsh
Dan.
Interesting idea, but no this is unspooled! Same as when on the spool and I have four of them.
Sure.Deviations from flat are due to impedance changes or mismatch. Check with Tek or HP literature on how to use and interpret the measurement.
THx-RNMarsh
The deviations are reasonably evenly spaced in time so perhaps the cable reel has been dropped heavily onto one side cheek, causing squashing of the cable on one side of the reel, and consequent change in characteristic impedance at intervals along the cable.
My suggestion is an informed guess ?.
I expect Ed well knows the reason and this is another of his valuable teaser questions/lessons.
Dan.
- Member Areas
- The Lounge
