CFA with diamond input buffer must be similar.
It was not offense. I like this topolgy too. And the DC servo You applied in the AX33/40 was really good idea.
I did lot of research regarding this topology, even hybrid version, with tube based voltage amplifier, and ss power buffer...
Sajti
If amp no need gain only buffer can be use.
That can be good idea. And if You use low impedance source (CD player, or same), you can put the volume control 1st, followed by the unity gain buffer. That is nice combination!
Sajti
It sounds great, if You use carefully selected parts. If not, only one OPA2134 will easily outperform it...
Sajti
OP for preamp is not fun 🙂
I agree with You. I don't like to use opamps. But I discussed about the sound quality, not the fun. It's very disappointing, if You build a very complicated amplifier, with bad sound quality, because of the bad parts You used...
Sajti
Simple stereo protect + PCB
any info what this about this protection circuit?
ex. overcurrent, dc protect, short circuit etc?....
I like the idea of a full P30 with own power supply and everything, etc.
Implementation of a multiple Line Inputs (with 2, 3 or more connections) with selector is also possible?
Thanks.
Thanks.
Hi everyone.
Here is my latest DIY audio amplifier with APEX - AX11 circuit.
I call it BG2 miniamp v3
BG2 miniamp v3 - 2x150W/4Ohm | DIY Projects
DC and delay start...
Thanks.
Input selector can be add,
Hi everyone.
Nice work,
Not based on an i.c but on separate parts(hi-fi)🙂Mile do you have a stereo preamp with tone control and volume on PCB ?
how about sound??![]()
NEVER ask about sound quality fron Apex it's BEST for diyer's
- 100W Ultimate Fidelity Amplifier
