The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
Hi andrea_mori:
Can you please add me to the list? I'm not sure which separate parts I should put my name in 🙂. Just hope it's not too late.
I need:
1 x 90.3168 MHz
1 x 98.304 MHz
1 x 45.1584 MHz
1 x 49.152 MHz
4 x PCB
4 x daughter board
Any other gear, if it's possible.
Thank you so much and happy new year!
Ian
Just added. As Olivier said, you need 2 daughter board.
I have not added the adapter board, I think you don't have any problem using your customized XO adapter. But if not so, please add yourself the adapter board to the list.
Can you please download the spreadsheet, fill it with your info and send me it back?
Andrea
1st batch - MOQ reached
* - andrea_mori : 8 x 5.6448MHz + 2 x 11.2896MHz + 3 X 22.5792 MHz + 3 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 12 x PCB + 6 x daughter board PCB + 10 x adapter board
* - Eldam : 1 x 5.6448MHz + 1 X 22.5792 MHz + 1 x 24.576 MH + 2 x daughter board PCB + 4 x PCB + 8 adapter boards
* - esgigt : 1 x 11.2896 Mhz + 1 x PCB, soldered if possible
* - fralippo : 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board PCB
- mravinsky : 2 x 11.2896 Mhz + 2 x XO PCB + 1 x Daughter board PCB
* - TNT : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, + 1 x daughter board, all soldered if possible + 4 x adapter board
- 1audio : 2x22.5792MHz 2x24.5760MHz + 2 x PCB + daughter board.
- randytsuch : 1x22.5792MHz 1x24.5760MHz + 4 x PCB + 1 x daughterboard
- myint67 : 1x11.2896mhz ,1x22.5792,1x45.1584,1x49.152 ,4 PCB ,2xdaughter board , soldered if possible
- kf_tam : 2x PCB
* - BDL : 1 x 11.2896 MHz + 4 x PCB + 1 x daughter board PCB + 4 x adapter board
- thorstenlarsen : 2 x 11.2896 MHz + 2 x PCB
- Zoran : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, (soldered or not...) + 1 x 11.2896 MHz + 1 x PCB
- walangalam : 1 x 11.2896 Mhz + 2 x PCB
- AR2: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB (soldering not needed)
* - mcluxun: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughterboard +2x adapter board (soldering if possible)
* - damohpi: 1 x 11.2896 + 1x PCB unsoldered
- noizas : 2 x 5.6448MHz + 2 x 11.2896MHz + 4 x PCB
- badrisuper : : 1 x 11.2896 Mhz + 2 x PCB
* - Clsidxxl: 1 x 22.5792 MHz + 1 x 24.576 MHz+1 x daughter board + 2 x PCB -With Assembly Service and 2 x adapter board
* - zeta4 1x 22.5792Mhz + 1 x PCB (soldering not needed)
* - hirez69: 1 x 22.5792 MHz and 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 33.8688 MHz+ 1 x 49.152 MHz + 6 x PCB (soldered) + 2 x daughter board + 4 x adapter
* - palmito : 1 x 45.1584 MHz + 1 x 49.152 MHz; 1 x 22.5792MHz 1 x 24.5760MHz; 2 PCBs; 2 daughter boards; 4 adapters.
* - gentlevoice: 1 x 22.5792MHz + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1*PCB
- naimster: 1x 22.5792 MHz + 1x 24.576 MHz + 2x PCB + 1x daughterboard (soldered if possible) + 2x adapter board
- zenelectro : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x daughterboard (soldered if possible)
* - Ryssen : 1 x 24.576 MHz + 1 x PCB soldered
* - flowerpot : 1 x 45.1584 MHz + 1 x 49.152 MHz + 4 x PCB + 2 x daughter board PCB + 4 x adapter board
* - deanoUK : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB + 2 x adapter board
* - Miklos: 1 x 11.2896MHz + 2 x PCB
- Kannan_s:1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
* - Acko : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB
- tuyen : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x daughterboard (soldered if possible)
* - Malvin : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB + 2 x adapter board
- Marlowe: 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 22.5792 MHz + 1 x 24.576 MHz + 8 x PCB + 3 x daughter board PCB
- Superdad: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board (soldered if possible)
* - vita:1 x 24.576Mhz + 6 PCB + 2 daughter board
* - ryanj 1 x 22.5792 Mhz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 3 PCB + 1 daughter PCB + 2 adapter PCB
* - justubes 1 x 11.2896 Mhz
* - JethroTull 1x 11.2896 Mhz + 2 PCB (with components, soldered o insoldered, it possible)
* - bson 4x 5.6448MHz + 2x 11.2896MHz + 4x PCB + 2x daughter board
* - jdlvfr 3 x 11.2896MHz
- jims 2 x 11.2896MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz, 2 X PCB, 2 X daughter boards
* - spm 1 x 22.5792 MHz, 1 x 24.5760 MHz, 1 x 45.1584 MHz + 1 x 49.1520 MHz + 4 x pcb + 2 x daughter boards +4 x adaptor pcbs
* - tbrowne: 2 x 22.5792 MHz, 1 x 24.5760 MHz, 1 x 45.1584 MHz
- iancanada: 1 x 45.1584 MHz + 1 x 49.152 MHz + 4 x PCB + 2 x daughter board
2nd batch - MOQ not yet reached
* - andrea_mori : 1 x 90.3168 MHz + 1 x 98.304 MHz
* - hirez69 : 1 x 90.3168 MHz + 1 x 98.304 MHz
* - flowerpot : 1 x 90.3168 MHz + 1 x 98.304 MHz
* - Miklos: 1 x 16.9344 MHz
- Marlowe: 3 x 16.9344Mhz + 3 x 25MHz
* - ppap64: 1 x 90.3168 MHz + 1 x 98.304 MHz + 2 x PCB + 1 x daughter board(soldered if possible)
- bkdog 1 x 90.3168 MHz + 1 x 98.304 MHz + 2 x PCB + 2 x daughter board (soldered if poss)
- jims 1 X 16.9344 MHZ
- carz 1 x 90.3168 Mhz, + 1 x 98.304 Mhz, + 1x 27MHz, + 3x pcb, + 3x daughter board
- iancanada: 1 x 90.3168 MHz + 1 x 98.304 MHz
Andrea
- kf_tam : 2x PCB
- deanoUK 1 x 90.3168 MHz + 1 x 98.304 MHz
I have added deanoUK 1 x 90.3168 MHz + 1 x 98.304 MHz.
Also sent Andrea a second order form for these.
Thanks.
OK.. SMA on both sides?
Yes, SMA on both side.
There could be a third option, a variation of the first: the same of the first option but using four separate regulators (+15V/+3V3 for each XO) instead of the power supply taken from the daughter board, soldering them directly to each XO via pin strips.
In this way all is local, but you need 4 regulators with a size that fits to the XO, like the expensive Tentlabs Shunt. Unless you do not want to cut the 4 regulators starting from 2 daughter board.
Could you please post final schema, lists etc in post #1?
Clocks board:
C1 and C2 - suggestion for component and also example make (mouser) and value?
R2, what variation for final value should we expect?
R6 / R7... quality?? Again make example please...
I see a SMA connector on clock board that I don't believe you have shown a schema with?
Aren't those crystals going to cost a lot of $/£ / Eur, have a long lead, and have a very high minimum order?
I requested an 11.2896Mhz OCXO quote from a Crystal manufacturer . Surprisingly they have come back and given a £200 per unit price and 20 week lead time.
Phase noise:-
-100dBc/Hz @ 10Hz
-130dBc/Hz @ 100Hz
-140dBc/Hz @ 1kHz
-145dBc/Hz @ 10kHz
There is a ocxo product with stat's below spec'd at 1Hz but if the above is quoted at that unit price I think below might be a tad expensive to make in odd frequencies.
Close-in phase noise at 5.0MHz
<-123 dBc/Hz @ 1Hz
<-140 @ 10Hz
Close-in phase noise at 10.0MHz
< -108 dBc/Hz @ 1Hz,
<-135 @ 10Hz
Schematics, BOM, PCB, documents, links and available parts
Finally I found the time to update.
Seems I cannot add document to post #1, so I publish all the document here.
Crystals:
11.2896 MHz MOQ 10 pcs Price € 27.00 each
22.5792 Mhz MOQ 10 pcs Price € 27.00 each
24.5760 MHz MOQ 10 pcs Price € 27.00 each
33.8688 MHz MOQ 10 pcs Price € 27.00 each
45.1584 MHz MOQ 10 pcs Price € 27.00 each
49.1520 MHz MOQ 10 pcs Price € 27.00 each
25.0000 MHz MOQ 10 pcs Price € 27.00 each
16.9344 MHz MOQ 10 pcs Price € 27.00 each
5.6448 MHz MOQ 15 pcs Price € 29.00 each
6.1440 MHz MOQ 15 pcs Price € 29.00 each
90.3168 MHz (3rd/5th) MOQ 15 pcs Price € 31.00/€ 29.00 each
98.3040 MHz (3rd/5th) MOQ 15 pcs Price € 31.00/€ 29.00 each
PCBs:
TWTMC-C (XO):
Size 1.75" x 1"
Board thickness 1 mm
Copper weight 70 um (2oz)
Surface finish Ni/Au
Unit price € 2
TWTMC- D&D (Daughter board):
Size 4.25" x 3.25"
Board thickness 1.2 mm
Unit price € 9
TWTMC- DIL (Adapter board):
Size 0.7" x 0.5"
Board thickness 1.6 mm
Unit price € 2
Order form for Crystals and PCBs:
See attached document TWTMC_OrderForm.Zip
Assembly service:
https://docs.google.com/forms/d/1od...ZBO19erk2LmXXHk/viewform?edit_requested=true#
Assembly manuals will be provided soon.
  • TWTMC-C.PDF
    TWTMC-C.PDF
  • TWTMC_OrderForm.zip
    TWTMC_OrderForm.zip
  • TWTMC-DIL_BOM.pdf
    TWTMC-DIL_BOM.pdf
  • TWTMC-DIL.PDF
    TWTMC-DIL.PDF
  • TWTMC-D&D_BOM.pdf
    TWTMC-D&D_BOM.pdf
  • TWTMC-D&D.PDF
    TWTMC-D&D.PDF
  • TWTMC-C_BOM.pdf
    TWTMC-C_BOM.pdf
In this case, with local +15V/+3V3 for each XO, no daughter board would be necessary at all if you just wanted the 2 freq full stop?
Update of list
- kf_tam : 2x PCB
* - noizas : 2 x 5.6448MHz + 3 x 11.2896MHz + 1 x 49.152 MHz + 10 x PCB + 3 x daughter board PCB + 4 x adapter board
* - noizas : 2 x 16.1584 MHz + 1 x 90.3168 MHz + 1 x 98.304 Mhz
In this case, if you would use external regulators you don't need any daughter board.
Or you can take out four separate regulators and two rectification/filtering by cutting two daughter board, as in the attached image.
Updated list
I have added 4 more 90.XXXX and 98.XXXX, so MOQ is reached.
I collected almost all order forms. Not yet received:
myint67
Zoran
badrisuper
tuyen
Marlowe
Superdad
bkdog
carz
Please, send me the order form as soon as possible. Thanks.
Next days I'll send all members the order form with prices and total amount, and the payment request.
* - andrea_mori : 7 x 5.6448MHz + 2 x 11.2896MHz + 3 X 22.5792 MHz + 3 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + + 5 x 90.3168 MHz + 5 x 98.304 MHz + 12 x PCB + 6 x daughter board PCB + 10 x adapter board
* - mravinsky : 2 x 11.2896 Mhz + + 2x22.5792MHz + 3 x XO PCB + 3 x Daughter board PCB
* - 1audio : 1X5.6448MHz 2x22.5792MHz 2x24.5760MHz 1X45.1584MHz 1X49.152 MHz 1X90.3168MHz 1X98.304MHz+ 1 x PCB
* - randytsuch : 1x22.5792MHz 1x24.5760MHz + 4 x PCB + 1 x daughterboard + 1 x adapter board
* - kf_tam : 2x PCB
* - thorstenlarsen : 2 x 11.2896 MHz + 2 x PCB
* - walangalam : 1 x 11.2896 Mhz + 2 x PCB
* - AR2: 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz + 2 x PCB + 2 x daughter board (soldering not needed)
* - noizas : 2 x 5.6448MHz + 3 x 11.2896MHz + 1 x 49.152 MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz + 10 x PCB + 3 x daughter board PCB + 4 x adapter board
* - hirez69: 1 x 22.5792 MHz and 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 33.8688 MHz+ 1 x 49.152 MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz + 6 x PCB (soldered) + 2 x daughter board + 4 x adapter
* - naimster: 1x 22.5792 MHz + 1x 24.576 MHz + 2x PCB + 1x daughterboard (soldered if possible) + 2x adapter board
* - zenelectro : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x + 1x adapter board + daughterboard (soldered if possible)
* - flowerpot : 1 x 45.1584 MHz + 1 x 49.152 MHz + 4 x PCB + + 1 x 90.3168 MHz + 1 x 98.304 MHz + 2 x daughter board PCB + 4 x adapter board
* - deanoUK : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x 90.3168 MHz + 1 x 98.304 MHz + 1 x daughter board PCB + 2 x adapter board
* - Kannan_s:1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 2 x daughter board PCB + 2 x adapter board
* - jims 2 x 11.2896MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz, 4 X PCB, 2 X daughter boards, 4 X adapter
* - iancanada: 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz + 4 x PCB + 2 x daughter board + 2 x adapter board
- carz 1 x 90.3168 Mhz, + 1 x 98.304 Mhz, + 3x pcb, + 3x daughter board
- carz 1x 27MHz
* - 1audio : 1X6.1440MHz
* - kf_tam : 2x PCB
- carz 1x 27MHz
- triodehunter: 1x 25.0000 MHz + 1x 45.1584 MHz + 1x 49.152 MHz + 3x pcb
Andrea, please count me in for the first batch, if still possible...
