The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
1st batch - MOQ reached
* - andrea_mori : 7 x 5.6448MHz + 2 x 11.2896MHz + 3 X 22.5792 MHz + 3 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + + 5 x 90.3168 MHz + 5 x 98.304 MHz + 12 x PCB + 6 x daughter board PCB + 10 x adapter board
* - Eldam : 1 x 5.6448MHz + 1 X 22.5792 MHz + 1 x 24.576 MH + 2 x daughter board PCB + 4 x PCB + 8 adapter boards
* - esgigt : 1 x 11.2896 Mhz + 1 x PCB, soldered if possible
* - fralippo : 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board PCB
* - mravinsky : 2 x 11.2896 Mhz + 3 x XO PCB + 3 x Daughter board PCB
* - TNT : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, + 1 x daughter board, all soldered if possible + 4 x adapter board
* - 1audio : 1X5.6448MHz 2x22.5792MHz 2x24.5760MHz 1X45.1584MHz 1X49.152 MHz 1X90.3168MHz 1X98.304MHz+ 1 x PCB
* - randytsuch : 1x22.5792MHz 1x24.5760MHz + 4 x PCB + 1 x daughterboard + 1 x adapter board
- myint67 : 1x11.2896mhz ,1x22.5792,1x45.1584,1x49.152 ,4 PCB ,2xdaughter board , soldered if possible
* - kf_tam : 2x PCB
* - BDL : 1 x 11.2896 MHz + 4 x PCB + 1 x daughter board PCB + 4 x adapter board
* - thorstenlarsen : 2 x 11.2896 MHz + 2 x PCB
- Zoran : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, (soldered or not...) + 1 x 11.2896 MHz + 1 x PCB
* - walangalam : 1 x 11.2896 Mhz + 2 x PCB
* - AR2: 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz + 2 x PCB + 2 x daughter board (soldering not needed)
* - mcluxun: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughterboard +2x adapter board (soldering if possible)
* - damohpi: 1 x 11.2896 + 1x PCB unsoldered
* - noizas : 2 x 5.6448MHz + 3 x 11.2896MHz + 1 x 49.152 MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz + 10 x PCB + 3 x daughter board PCB + 4 x adapter board
- badrisuper : : 1 x 11.2896 Mhz + 2 x PCB
* - Clsidxxl: 1 x 22.5792 MHz + 1 x 24.576 MHz+1 x daughter board + 2 x PCB -With Assembly Service and 2 x adapter board
* - zeta4 1x 22.5792Mhz + 1 x PCB (soldering not needed)
* - hirez69: 1 x 22.5792 MHz and 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 33.8688 MHz+ 1 x 49.152 MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz + 6 x PCB (soldered) + 2 x daughter board + 4 x adapter
* - palmito : 1 x 45.1584 MHz + 1 x 49.152 MHz; 1 x 22.5792MHz 1 x 24.5760MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz; 2 PCBs; 2 daughter boards; 4 adapters.
* - gentlevoice: 1 x 22.5792MHz + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1*PCB
* - naimster: 1x 22.5792 MHz + 1x 24.576 MHz + 2x PCB + 1x daughterboard (soldered if possible) + 2x adapter board
* - zenelectro : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x + 1x adapter board + daughterboard (soldered if possible)
* - Ryssen : 1 x 24.576 MHz + 1 x PCB soldered
* - flowerpot : 1 x 45.1584 MHz + 1 x 49.152 MHz + 4 x PCB + 1 x 90.3168 MHz + 1 x 98.304 MHz + 2 x daughter board PCB + 4 x adapter board
* - deanoUK : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x 90.3168 MHz + 1 x 98.304 MHz + 1 x daughter board PCB + 2 x adapter board
* - Miklos: 1 x 11.2896MHz + 2 x PCB
* - Kannan_s:1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 2 x daughter board PCB + 2 x adapter board
* - Acko : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB
- tuyen : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x daughterboard (soldered if possible)
* - Malvin : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB + 2 x adapter board
- Marlowe: 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 22.5792 MHz + 1 x 24.576 MHz + 8 x PCB + 3 x daughter board PCB
- Superdad: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board (soldered if possible)
* - vita:1 x 24.576Mhz + 6 PCB + 2 daughter board
* - ryanj 1 x 22.5792 Mhz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 3 PCB + 1 daughter PCB + 2 adapter PCB
* - justubes 1 x 11.2896 Mhz
* - JethroTull 1x 11.2896 Mhz + 2 PCB (with components, soldered o insoldered, it possible)
* - bson 4x 5.6448MHz + 2x 11.2896MHz + 4x PCB + 2x daughter board
* - jdlvfr 3 x 11.2896MHz
* - jims 2 x 11.2896MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz, 4 X PCB, 2 X daughter boards, 4 X adapter
* - spm 1 x 22.5792 MHz, 1 x 24.5760 MHz, 1 x 45.1584 MHz + 1 x 49.1520 MHz + 4 x pcb + 2 x daughter boards +4 x adaptor pcbs
* - tbrowne: 2 x 22.5792 MHz, 1 x 24.5760 MHz, 1 x 45.1584 MHz
* - iancanada: 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz + 4 x PCB + 2 x daughter board + 2 x adapter board
* - ppap64: 1 x 90.3168 MHz + 1 x 98.304 MHz + 2 x PCB + 1 x daughter board(soldered if possible)
- bkdog 1 x 90.3168 MHz + 1 x 98.304 MHz + 2 x PCB + 2 x daughter board (soldered if poss)
- carz 1 x 90.3168 Mhz, + 1 x 98.304 Mhz, + 3x pcb, + 3x daughter board
* - triodehunter: 1x 45.1584 MHz + 1x 49.152 MHz + 3x pcb
* - tods : 1 x 45.1584 MHz + 1 x 49.152 MHz; 1 x 22.5792MHz 1 x 24.5760MHz ; 4 PCBs; 2 daughter boards; 4 adapters.
2nd batch - MOQ not yet reached
* - Miklos: 1 x 16.9344 MHz
- Marlowe: 3 x 16.9344Mhz + 3 x 25MHz
- carz 1x 27MHz
* - 1audio : 1X6.1440MHz
* - mravinsky : 1 x 16.9344Mhz
* - triodehunter: 1x 25.0000 MHz
* - TNT : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, + 2 x daughter board + 4 x adapter board
* - kf_tam : 2x PCB
- carz 1x 27MHz
(removed assembly, added 1 DB)
* - kf_tam : 2x PCB
- carz 1x 27MHz
- Stijn001: 1 x 45.1584 MHz + 1 x 49.152 MHz; 2 PCBs; 2 daughter boards, 2 adapters boards
For those who love "bricolage" this is the third option to connect to Ian's Dual XO board.
Power supply only should be wired, cannibalizing a couple of daughter board.
Re added 2 x 16.1584 MHz
* - kf_tam : 2x PCB
- carz 1x 27MHz
* - noizas : 2 x 16.9344 MHz
Hi Andrea,
it looks like I by mistake have added 2 x 16.1584 MHz to the list of 2nd batch :cubehead:. So you have removed it.
However correct information is in my order form - 2 x 16.9344 MHz, so I decided to re-add those back to 2nd batch. Still it is not enough for MOQ :worried:
Best wishes
Saulius
* - kf_tam : 2x PCB
* - duster1: 1 x 90.3168 MHz + 1 x 98.304 MHz + 4 x PCB + 2 x daughter board + 4 x adapter board
- carz 1x 27MHz
Closing the list
I have not yet received order form from the following members:
myint67
Zoran
badrisuper
tuyen
Marlowe
Superdad
bkdog
carz
Stijn001
I ask the above members to send me the order form as soon as possible.
As soon as the payment for Laptech crystals will be made, the first batch will be closed, and pending orders will be automatically shifted to the second batch.
How long will it take before we can pay for the assembly?
I'm collecting payment for the received orders.
As soon as I have received all the payment, I'll pay Laptech for the crystals.
Laptech asks 8-9 weeks lead time, I hope they will reduce that time, delivering the crystals within the end of February.
As soon as I will receive the crystals I'll ship immediately.
In the meantime, who needs assembly service, please, fill the document provided by Phil (korben69), so he can quote the service and ask for the payment.
Thanks all
Andrea
Andrea
Very interesting project. Thank you for all your efforts!
I came to know that crystals and oscillators can have variances in phase noise performance sometimes by as much as 30% in a typical production batch. There is a guy doing custom grading for many brands. He thinks manufacturers generally provide carefully curated samples for favourable evaluation but the actual production versions are mostly crap.
Will you do any tests to check against this or I assume you are just depending on device characterization?
Another question: re: the 45/49.xx or 22/24.xxx types have better noise
figures?
TIA,
Shane, Acko
as you know SC-cut crystal needs an oven to work, so the project become more complex. That's the reason I have chosen AT-cut crystal.
I don't have feedback about phase noise from the manufacturer, because the phase noise is a typical oscillator parameter, rather than a crystal parameter. BTW, fundamental mode crystals from Laptech are manufactured by means of a strong polish finish, to ensure almost perfect crystal surface. This usually helps to reach good phase noise performance close to the carrier.
The plot I posted at #5 of this thread shows a phase noise of -100dBc at 1Hz from the carrier using this Clapp oscillator and a crystal from the german QT, a resistance welded crystal with polish finish. The Laptech one is a cold weld package crystal with superior specs: very low ESR (less than 10 ohm), low motional capacitance (that usually means high Q) and high production quality level. They test each crystal and discard those who don't reach standard specs.
Difficult to say about 22/24/45/49.XXX phase noise. Phase noise of an oscillator usually increases with higher frequencies. However, 45/49.XXX are 3rd overtone, which usually means higher Q, that helps to reduce the phase noise.
Hi Andrea,
Will you give us a measured mounted board spreadsheet (let say 11.2888 took in the GB shipment) maid by your "german" contact who have a sota measurement bench, or maybe have you access to such devices in your near environment ?
It can give us a prof of concept if at the end both the design and current Laptech production worth the effort?
Hi Andrea,
As I said in the first post of this thread, I have limited access to the university lab, so I will give a measurement when all the 3 oscillators will be ready (Clapp, Butler and Driscoll types).
I would own a suitable measurement gear to do myself the phase noise test, but unfortunately such gear costs several tens of thousand USD/Euro.
