in addition, you should reference the SMPS 0V to earth.
This helps a lot to remove the hum.
Connex suggest to either use a direct cable or via a small resistor on the SMPS800R board. I used a 10R resistor.
I'm planning to use a L15D module for my subwoofer. Is there any modification which can be made to use it as a sub woofer amplifier? Or is it better with the default configuration? Please help
No Pic. 😱
See Post #870
Wich is better with l25d 4 or 16ohm speakers? Can connect 8ohm woofers in series or parallel...
Paralell.
I have one extra l25d and one transformer at +-45dc, wich resistors and values do I have replace for the low voltage transformer to be used?
Will I get more power in 4r with the l15d?
Dont want to buy another board 🙂
The output power of the L15D and L25D at 4 ohms at 45DC rails will be the same .
The resistors you have to replace are described in the iraudamp7 datasheet , but I attached it for your convenience . Go for the 150 one .
See http://www.diyaudio.com/forums/clas...-irs2092-irfi4020h-200w8r-34.html#post2933914 for reference .
Cheers ,
Rens
Ok, all eight resistors?
All 8 resistors have the values in the amp7s-150 column on my L15D board ( 2W for the power resistors )
Cheers ,
Rens
I'm certainly not naive to believe there are no fake components being used on all matter of boards from Asia or other places. But why would someone go to all the trouble of producing a super quality board and then place second rate, or inferior components on it? Profit you say...
Even in China it's in no ones best interest to build inferior parts just to save a couple nickels. We're living in the internet age where information travels in milliseconds not weeks. Word gets around real fast about bad products - and good. If these caps were know to cause fires - even anecdotally - the manufacturers reputation would be at risk and board makers would find other suppliers - real fast.
But I'll take you at your word and the next time I order any e-caps I'll order an extra one for purposes of destroying it just to identify the real manufacturer. 😱 Can you post a picture of one with the top removed revealing the manufacturers name?
In China there are a lot of, not real capacitance.
Is everybody say. Counterfeit products.
You can watch the capacitance plastic leather. Can have obvious fakes, a crack.
I am capacitance experts. I can judge for 100% with pictures of true and false of the capacitance.
Any questions about this, you can mail to me.
ljm_ljm@foxmail.com
In addition. At present I haven't even 10000 UF capacitance.
For now, I only have this kind of rectifier circuit, is suitable for L20D L25D
It's not large capacity electrolytic capacitor.
Is composed of many small capacitance in parallel. 75V220UF rubycon YXF *68PCS
I won't let any counterfeit capacitance in the my products.
But I can't stop sold fake electronic components.
Hi ljm
Is it possible to purchase 2 L25d boards with only the IRS chip pre-soldered ?
Sent from my Nexus 7 using Tapatalk
Hi ljm
what is the chip pre-soldered.
sorry My English level is not good.
mr ljm_ljm: can u share the layout PCB in soft file in sprint layout or proteus? or send me email in angginurcahyo@gmail.com. please... and thank you so much
Hello To all, I bought and built two boards.
I also bought a power supply and I'm in the testing phase.
I'm quite sure that the PCB are OK but they do not work.
The blue led is off and, now, I have doubts on the power supply.
Here a picture of the connections, do you see any problem ?
I've regulated the VDC to 68v.
Any help is appreciated.
Cheers, RA
Cheers, RA
Cheers, RA
You'll need DUAL rail supply + and - 60V !! AND 0 Volts
Your supply is only positive +60V
Buy a second one and you'll be alright if you connect them in series and use the serial connection as 0 V but better buy a dual rail +/- 60V supply something like this Connexelectronic
Cheers ,
Rens
ARG stupid me.......
Thanks for the answer..
I'll get a new one with double output..
Cheers, RA
Cheers, RA
This is a good New Year's joke.
Do you think these two componente can solve my problems ?
1) toroidal tranformer (I have one used with 50V secondary and not 55V) : Nuvotem Talema RS0500P1-2-050 (Buy Toroidal Transformers 2 Output Toroidal Transformer, 500VA, 50 V ac Nuvotem Talema 0500P1-2-050 online from RS for next day delivery.)
2) power supply (I have one of this ): 68pcs 75V220UF NIPPON matrix Power supply board for L20D L25D 120 HZ
thanks, RA
thanks, RA
- Class D
- My design L20D IRS2092+IRFI4020H 200W8R
