The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
Since there are many members who want use this clock with Ian's Dual clock board, I have designed a little board that fits directly to DIL socket.
The board provides three type of connector that could be used to connect XO board:
- 1 x u.fl connector
- 1 x SMA connector
- 2 x pin strip connector (to adapt left and right DIL socket on Ian's board)
Using pin strip connector, XO board could be soldered directly to the adapter board, avoiding any cable.
With this option, Xo's power supply (+15V, +5V/+3V3) should be wired to the daughter board, using a suitable wire triplette for each XO (+15V, +5V/+3V3, GND).
Board size is 0.7" * 0.55", 1.6 mm thickness, 2oz copper, ENIG finish.
If there will be enough interest, this adapter board could be supplied.
The cost for a quantity of 100 pcs is around EUR 2.00 each board.
For 50 pcs the cost increases to EUR 3.50 each board.
If anyone was interested, please add this option to the list.
Very nice adapter Andrea,thank,SMA connector allows the use of cables semi-rigid coaxial,to a clock signal it is optimal
SMA Male Plug to SMA Male Connector for Pigtail Semi Rigid 141''RG402 15cm Hot | eBay
Here between the double XO and the I2StoPCMconvertorBoard
img66192 partagé sur ZimageZ
- andrea_mori : 5 x 5.6448MHz + 2 x 11.2896MHz + 3 X 22.5792 MHz + 3 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 90.3168 MHz + 1 x 98.304 MHz + 10 x PCB + 4 x daughter board PCB + 8 x adapter board
- Eldam : 1 x 5.6448MHz + 1 X 22.5792 MHz + 1 x 24.576 MH + 2 x daughter board PCB + 4 x PCB
- esgigt : 1 x 11.2896 Mhz + 1 x PCB, soldered if possible
- fralippo : 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board PCB
- mravinsky : 2 x 11.2896 Mhz + 2 x XO PCB + 1 x Daughter board PCB
- TNT : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, + 1 x daughter board, all soldered if possible
- 1audio : 2x22.5792MHz 2x24.5760MHz + 2 x PCB + daughter board.
- randytsuch : 1x22.5792MHz 1x24.5760MHz + 4 x PCB + 1 x daughterboard
- myint67 : 1x11.2896mhz ,1x22.5792,1x45.1584,1x49.152 ,4 PCB ,2xdaughter board , soldered if possible
- kf_tam : 2x PCB
- BDL : 1 x 11.2896 MHz + 4 x PCB + 1 x daughter board PCB
- thorstenlarsen : 2 x 11.2896 MHz + 2 x PCB
- Zoran : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, (soldered or not...) + 1 x 11.2896 MHz + 1 x PCB
- walangalam : 1 x 11.2896 Mhz + 2 x PCB
- AR2: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB (soldering not needed)
- mcluxun: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughterboard (soldering if possible)
- damohpi: 1 x 11.2896 + 1x PCB unsoldered
- noizas : 2 x 5.6448MHz + 2 x 11.2896MHz + 4 x PCB
- badrisuper : : 1 x 11.2896 Mhz + 2 x PCB
- Clsidxxl: 1 x 22.5792 MHz + 1 x 24.576 MHz+1 x daughter board + 2 x PCB -With Assembly Service and 2 x adapter board
- zeta4 1x 22.5792Mhz + 1 x PCB (soldering not needed)
- hirez69: 1 x 22.5792 MHz and 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 4 x PCB (soldered) + 1 x daughter board
- palmito : 1 x 45.1584 MHz + 1 x 49.152 MHz; 1 x 22.5792MHz 1 x 24.5760MHz; 2 PCBs; 2 daughter boards.
- gentlevoice: 1 x 22.5792MHz + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1*PCB
- naimster: 1x 22.5792 MHz + 1x 24.576 MHz + 2x PCB + 1x daughterboard (soldered if possible)
- zenelectro : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x daughterboard (soldered if possible)
- Ryssen : 1 x 24.576 MHz + 1 x PCB soldered
- flowerpot : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- deanoUK : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- Miklos: 1 x 11.2896MHz + 2 x PCB + 1 x 16.9344 MHz
- Kannan_s:1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- Acko : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- tuyen : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB's + 1 x daughterboard (soldered if possible)
- Malvin : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB
- Marlowe: 3 x 16.9344Mhz + 3 x 25MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 22.5792 MHz + 1 x 24.576 MHz + 8 x PCB + 3 x daughter board PCB
- ppap64: 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board(soldered if possible)
- Superdad: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughter board (soldered if possible)
- vita:1 x 24.576Mhz + 6 PCB
- bkdog 1 x 90.3168 MHz + 1 x 98.304 MHz + 2 x PCB + 2 x daughter board (soldered if poss)
- ryanj 1 x 11.2896 Mhz + 1 PCB + 1 daughter PCB
- justubes 1 x 11.2896 Mhz
- JethroTull 1x 11.2896 Mhz + 2 PCB (with components, soldered o insoldered, it possible)
- kf_tam : 2x PCB
- naimster: 1x 22.5792 MHz + 1x 24.576 MHz + 2x PCB + 1x daughterboard (soldered if possible) + 2x adapter board
- kf_tam : 2x PCB
- BDL : 1 x 11.2896 MHz + 4 x PCB + 1 x daughter board PCB + 4 x adapter board
- kf_tam : 2x PCB
- Malvin : 1 x 45.1584 MHz + 1 x 49.152 MHz + 2 x PCB + 1 x daughter board PCB + 2 x adapter board
- kf_tam : 2x PCB
- ryanj 1 x 11.2896 Mhz + 1 PCB + 1 daughter PCB + 1 adapter PCB
- TNT : 1x22.5792MHz 1x24.5760MHz + 2 x PCB, + 1 x daughter board, all soldered if possible + 4 x adapter board
- kf_tam : 2x PCB
- kf_tam : 2x PCB
- mcluxun: 1 x 22.5792 MHz and 1 x 24.576 MHz + 2 x PCB + 1 x daughterboard +2x adapter board (soldering if possible)
- kf_tam : 2x PCB
- bson 4x 5.6448MHz + 2x 11.2896MHz + 4x PCB + 2x daughter board
- kf_tam : 2x PCB
- jdlvfr 3 x 11.2896MHz
- kf_tam : 2x PCB
-jims 2 x 11.2896MHz + 1 X 16.9344 MHZ + 1 x 45.1584 MHz + 1 x 49.152 MHz, 2 X PCB, 2 X daughter boards
What would be the best option to run an NXP LPC arm7tdmi slaved off a TWTMC? A 12x multiplier to get close to 67.7376MHz? Exact precision isn't critical, I just want a fixed ratio that doesn't drift or vary...
I'm not skilled about uC, but I'm curious about your project.
What DAC are you planning to use? What is the source?
Have you never thought to run asynchronously DAC and uC, and then slaving the uC via interrupt?
For example, thinking to TDA1541A, one can run freely the dac at 1.4112 MHz (direct feeding from master clock, BCK and WS), and then, when the dac needs one more bit asks the uC (that run freely at its right frequency) to provide it using interrupt function?
- kf_tam : 2x PCB
- jims 2 x 11.2896MHz + 1 X 16.9344 MHZ + 1 x 45.1584 MHz + 1 x 49.152 MHz, 2 X PCB, 2 X daughter boards
- spm 1 x 22.5792 MHz, 1 x 24.5760 MHz, 1 x 45.1584 MHz + 1 x 49.1520 MHz + 4 x pcb + 2 x daughter boards +4 x adaptor pcbs
Update : adding adapter boards
- Eldam : 1 x 5.6448MHz + 1 X 22.5792 MHz + 1 x 24.576 MH + 2 x daughter board PCB + 4 x PCB + 4 adapter boards
- kf_tam : 2x PCB
update
- kf_tam : 2x PCB
- vita:1 x 24.576Mhz + 6 PCB + 2 daughter board
update
- kf_tam : 2x PCB
I'm putting together a discrete DSD decoder as a learning project... basically the uC fills up a FIFO and the master clock drains it into optocouplers (6N137). Having the two operate at a known integer ratio makes timing calculations easier and avoids odd sources of timing glitches. But then it's not likely to be a problem anyway...
Updated
- kf_tam : 2x PCB
Please, pay attention to copy the last list when updating. Thanks.
- kf_tam : 2x PCB
- carz 1 x 90.3168 Mhz, + 1 x 98.304 Mhz, + 1x 27MHz, + 3x pcb, + 3x daughter board
