No NFB line amp (GainWire mk2)
I'm nearly finish one channel of the pre-amp, only R30, R31 left. I don't have 180R for them. But I do have 200R, 221R and org 270R. Which one should I use? Any change in perfomance?
I use gain 3.5x setting.
Higher those resistors more current though output transistors. I originally used 270R in those positions, but with my small heat sink on Q23, Q24 they get a bit to hot. Try with 200R, if you want to use low impedance headphones you can try 221R or even 270R. Check the temperature of Q23, Q24.
The gain setting does not have anything with those resistors.
When you do listening, please report back your impression.
I finished one channel of the pre-amp, after some problem with the PSU (I swapped 10R / 100R and it cause too much voltage drop on negative channel). Other channel will be wait for missing component (I bought them but lost them now). This is the first DIY project to me.
My gain is: 3.5x
R30, R31 = 221 Ohms
All small caps are 220pf
I didn't have fancy equipment or headphone. My test equipment are:
Source: HiFimeDIY Sabre v2
Headphone: KRK KNS6400
When testing. I thinked Gainwire mkII is quite nature in sound. CFA make sound a litle grainier, NOGFB make sound a bit more sweet. I need to test more and decide which mode will suit me better. And it is sound good to me, much better than some CMOYs, low voltage tube headphone amp which I used before.
One problem, when no source connect, I hear a little buzz in my headphone but it gone when connect any source. Is it some kind of problem?
And I'm interested with a SMD version of the preamp, too.
My gain is: 3.5x
R30, R31 = 221 Ohms
I am glad that you like the sound. You have nice board there, have you made the layout looking to my layout? Excellent for first DIY project.
Regarding the buzz it could be a grounding problem, I have no buzz source connected or not.
I would like to make a SMD version, but that is a new field for me and I need time for that.
Damir
Damir
Yes, I made them when looking at your board, it is the same layout as yours but using my specific component footprint. I wish I could order the board from you but I got bad experience with my country shipping service.
About the buzz, when no source connected, the voltage between input + and - is 16mV, is it because of mismatch of the bjt vbe? The output DC is 0.1mV.
Probably, and DC servo corrects output offset. Try with no opamp and see the dc offset.
