Preamp-Buffers - simple idea
Another ignorant question, before to connect the buffer to the PSU LM317/337 I adjusted the PSU to give +-15VDC without load, when I connected the buffer to the PSU the voltage down to +3,91 VDC and -1,19VDC, the tx is 0-22VAC 1A main filter cap is 4.700uF
Something is wrong, possibly short circuit or burned JFET(s) in your buffer.
Check carefully (without voltage applied) wiring and check all JFETs between D and S with an Ohmmeter.
Attached pic showing how I connected the PSU to the Buffer.
Merlin,
do you have a CRC Filter in your PSU? During startup the buffer draws quite some current until it settles to the designed bias current. I have the same (well not that extreme) with my SMD Calvin buffers. However after a few seconds it adjusts to expected behaviour.
Just a thought...
Joshua, I really don't know. It may have been one of the headphone forums or AudioKarma where someone made the statement that the Siliconix 4391's were better than the Fairchilds.
Maybe dodo can shed some light on the differences since he made the statement the "Fairchilds are much worse than Vishay 2N4391".
It's ALIVE!
I finally got one channel of this buffer completed this evening.
I only built one channel initially to see if it was going to play music or go up in smoke.:flame:
Much to my surprise it does play music. I was able to get the DC offset between 0 and 1mv after adjusting the trimmer pot.🙂
I'll assemble the other channel and see how it sounds connected to my Adcom 535II amplifier.
Soldering those little SMD resistors does take some time.:snail:
Saying that "A" is better than "B" without specifying in what it's better and in what application it's so, is meaningless.
Well done.
