Class D Amp with LM566, LM393 and 2XIRF530
D200.2 image
Hi Apex
Power suply +56,-56,0 V, Bias IR2110 11.4 V. Use FET IRFP260N. Coil is warm not hot.
Can you help me......
Many thanks.
  • apex d200 v2 linh kien.pdf
  • apex d200 v2 final layout.pdf
Hi Apex .
I use Sendust core PS184026 , AL = 26, Values we need is = 33uH.
The formula for calculating it
n =SQRT(nH/Al) = =SQRT(33000/26) = 36 turn. Check again by Multi Meter OK. Can you recommend me a good MostFet ?
Thanks Apex.
Some pictures of Apex D200. I am testing it with +- 35VDC an its play loud with stong bass. The high are a little too agresive for my taste ,but for the my first D class amp its OK.Fets are just a little warm the coil is at room temperature, all in all very good.
Regard
zoky2
