ExtremA, class-A strikes back?
Re class A+, this is the principle.
20V amplitude of 20kHz sine makes 2.513V/us at zero crossing. You need 5 - 10x more to get reasonably low 19+20kHz CCIF.
Bridge needs 2x higher slew rate.
If you would like to learn the formula, it is SR = max.(dv/dt) = 2 x pi x F x Vp, Vp is amplitude of the sine wave.
You also need to handle possible EMI spikes from D/A converters etc.
And if you design the amplifier down to that minimum slew rate you find that distortion increases enormously well before the limiting slew rate is reached.
Many have concluded that the required slew rate should be around 5times h#what the signal slew rate is and some have gone straight to 10times as adequate slew capability to cater for maximum slew in the signal.
Now back to the nonsense statement
For good sound sufficient SR 1,6V/µs.
High audio frequency never have large amplitudes.
edit,
I see PMA is stating the same 5 to 10times requirement.
For my amusement I calculated the output errors for ExtremeAB, that is, class AB output at 1/2 max output current bias. At this level there is no crossover at all and only a small amount of compressive 3rd's. With .28 Ohm emitter resistors the open-loop output resistance modulates only .14 Ohm to .165 Ohm, of course with the feedback it is constant .14 Ohm. Open-loop distortion at full 100W is .024% thirds. At only 48dB gain at 20K all distortion above PPM levels will be from the rest of the circuit and the build. The AB does not hit the wall at 5A.
I agree with PMA that there are probably many front ends that work including an op-amp.
