For good sound sufficient SR 1,6V/µs.
High audio frequency never have large amplitudes.
Plain nonsense.
I couldn't resist whipping up Pavel's idea in the simulator, made it into a full bridge for better efficiency and set the output for 80W/8R. The numbers I got aren't in the least bit disappointing, here's the THD20K at 80W/8R:
Fourier components of I(r38)
DC component:1.88071e-006
Harmonic Frequency Fourier Normalized Phase Normalized
Number [Hz] Component Component [degree] Phase [deg]
1 2.000e+04 3.171e+00 1.000e+00 -0.28° 0.00°
2 4.000e+04 3.375e-06 1.064e-06 -55.67° -55.39°
3 6.000e+04 5.025e-06 1.585e-06 -118.35° -118.07°
4 8.000e+04 2.325e-06 7.333e-07 157.09° 157.37°
5 1.000e+05 1.683e-06 5.308e-07 77.54° 77.82°
6 1.200e+05 9.958e-07 3.141e-07 0.57° 0.85°
7 1.400e+05 4.393e-07 1.386e-07 -107.32° -107.04°
8 1.600e+05 4.818e-07 1.520e-07 101.26° 101.54°
9 1.800e+05 8.989e-07 2.835e-07 7.13° 7.41°
Total Harmonic Distortion: 0.000216%(0.008551%)
Alright, simulated efficiency is 186W in, 80W out, that's 80/186 > 43%, not bad considering this is class-A.
Try to run asc file
http://www.diyaudio.com/forums/solid-state/96853-extrema-class-strikes-back-30.html#post4120514
Fourier components of I(r40)
DC component:0.000407211
1 1.000e+04 2.669e+00 1.000e+00 178.12° 0.00°
2 2.000e+04 5.812e-08 2.178e-08 3.00° -175.12°
3 3.000e+04 5.652e-06 2.118e-06 -124.58° -302.70°
4 4.000e+04 3.135e-08 1.174e-08 -0.20° -178.32°
5 5.000e+04 3.423e-07 1.282e-07 67.10° -111.03°
6 6.000e+04 2.038e-08 7.636e-09 0.03° -178.09°
7 7.000e+04 2.216e-08 8.303e-09 -60.47° -238.59°
8 8.000e+04 1.510e-08 5.659e-09 -0.11° -178.23°
9 9.000e+04 1.385e-08 5.188e-09 5.15° -172.97°
Total Harmonic Distortion: 0.000212%
Try to run asc file
Are you referring to the discrete design, or the opamp design? I'm assuming the former? In that case, .four 20k I(R40) is what you'd like to use.
SSassen,
Power supply can be lower (V2 and V3 = 18-20V).
Correct, with 20V per rail for the output stage there's a bit of headroom left still and efficiency goes up. Simulated efficiency is 152W in 80W out, which is 80/152 > 53%.
So try it, simply edit 10kHz to 20kHz...four 20k I(R40) is what you'd like to use.
DC component:0.000265904
1 2.000e+04 3.465e+00 1.000e+00 176.23° 0.00°
2 4.000e+04 8.835e-09 2.550e-09 28.75° -147.48°
3 6.000e+04 4.338e-06 1.252e-06 -138.55° -314.78°
4 8.000e+04 1.114e-08 3.216e-09 -8.34° -184.57°
5 1.000e+05 3.114e-06 8.989e-07 63.60° -112.63°
6 1.200e+05 5.183e-09 1.496e-09 -7.20° -183.43°
7 1.400e+05 3.595e-07 1.037e-07 -119.38° -295.61°
8 1.600e+05 3.816e-09 1.101e-09 -12.84° -189.07°
9 1.800e+05 4.946e-08 1.427e-08 61.28° -114.96°
Total Harmonic Distortion: 0.000154%
I'm sorry, I'm not entirely sure what you'd like me to do? You also need to change the input to SINE(0 1.4 20k) if you want to look at THD@20K.
@BV,
You're referring to your post #298 correct? If you can forward me the .asc I can have a closer look, I can be reached at ssassen(at)hardwareanalysis(dot)com, feel free to email the .asc to that address.
Sine source is defined this way, "SINE(0 1.3 {freq} 0 0 0 10)", and parameter {freq} is defined in schematic as spice directive line ".param Freq=20k". So it is enough to edit 10kHz to 20kHz in this line...
And .asc file is in post 298 .
I'm sorry, but I don't need tutoring on how to use LTspice 😀
SSassen,
With 2 x 18V for the opamp, you need at least 2 x 22V for the output stage (ccs and triple junction margin), otherwise distortion gets higher).
😎🙂 Nice idea.
Kinda reminds me of driving a OPS bias pair with ref to the output. Conceptually, wasnt that done in a former life with a diode-resistor from output to bias (spreader)? (NPass). But this is a nice balanced circuit refinement.... like a comparitor, too.
Opamp input now then one of the many good discrete front end, later?
THx-RNMarsh
THx-RNMarsh
This OPS input current is, hopefully, only in microamperes, as long as the output stage remains in class A. That's all the magic - it almost does not load opamp output.
No load on the opamp is great as that was the last area of concern (OPS loading) for using opamps. How much current does the sim say the opamp must supply (max) when the amp goes out of class A?
THx-RNMarsh
THx-RNMarsh
THx-RNMarsh
Not nice, then. Starts quite mild, as attached, but continues to milliamps and tens of milliamps.
The image is for stepped load 8, 6, 4 ohms. You can see input current and ouput current through one output device.
added an image for 2 ohm load
2 SSassen
So why You ask this?I'm sorry, but I don't need tutoring on how to use LTspice
How much is the (theoretical) maximal efficiency of this OPS?...Simulated efficiency is 152W in 80W out, which is 80/152 > 53%.
You have to specify idle current first. Otherwise there is no good answer.
Class A for 8 ohms only, or for 4 ohms as well, or for 2 ohms as well? Idle current is half peak current to stay in class A.
- ExtremA, class-A strikes back?
