DAC gallery
Transformers
I have Lundahls too. I am having very good luck with Cinemag transformers. They are more affordable then Lundahls. These days I just use transformers for all my filtering. No loss of details... just beware of putting to much voltage across them. In my case less then 1 mV. Enjoy one of the best kept secrets in digital. :spin:
Here is the one I built. It's all on one PCB and is all surface mount except the power supply stuff. I think the regulators could have also been SMT to save a little space as well. This DAC was designed by a friend of mine out east. All the SMT soldering was done by myself and all the parts are easily available off the shelf.
Mark
Mark
Lovely bit of work. The CS4398 is the chip I use on a Cirrus Logic demo board from 2000. You can run cap couples off the V+ left and right and the sound is very detailed, but slightly cool in the mid. I would think using the +- voltage outs on the DAC with the Lundahl will be warmer, and bring the balance of bass mid and treble in line and also filter out any noise.
Members of the "Sound DIY" Club have built seven or eight of the "Buffalo" DACs (I, II & III) and have tried comparing them against several other well known Commercial DACs. So far the Buffalo DAC has held it's own, or actuakky surpassed every single comparison with DACs up to $5K and is an absolute bargin for the price of the "Buffalo" Kit !
Great Dac!
Best Regards,
TerryO
Apparently I impose standards that Sabre is unable to meet
I can for example claim that PCM1794 is best for my own preferences.
But the assertion that something is "in any circumstances best", is definitely unjustifiable.
Since I have not claimed or asserted that anything "is in any circumstances best", can I therefore assume that you are speaking of some another person's claim?
TerryO
But you stated that "performs well by "any" standard that you wish to impose."
As I wish to impose standards that Sabre cannot meet, your claim is obviously enthusiastic in excess. One can claim that never heard anything performing better than X (and that is enthusiastic enaugh), but cannot claim that anything better than X doesn't exist (and that is enthusiastic in excess, unjustified).
I can agree that Sabre is good, or very good, or even one of the best, but cannot agree that is best at all. Noone really can.
Nothing personal, just elucidation.
Thanks for "elucidating" on what you are saying by using a claim that is not only unstated, but probably non-existant. Just the same, now that I'm aware of the direction you're taking this, I will get out of the way, in order that your ego may have a clear and open field to exercise.
Nothing personal of course. Goodbye.....
(...)Just the same, now that I'm aware of the direction you're taking this, I will get out of the way, in order that your ego may have a clear and open field to exercise.
You probably did not understand me. Possibly due to my not very good english. So, I sturdily doubt that you are "aware of the direction I'm taking this". The only thing I want add is to declare that my ego has nothing to do with it. And as I'm not pleased to expose myself to the allegations ad personam, I quit.
Hi, this is my Buffalo III DAC.
The output BAL->SE is done à la Ciuffoli, with amorphous Lundahl transformers and Mundorf Supreme + teflon caps.
It has 3 selectable output channels.
It has two input channels: one Amanero async I2S USB and one S/PDIF.
The Amanero board is isolated by a Texas Instruments ISO7640 digital isolator (done the SMD board and soldering myself, it wasn't easy...)
The raw PSU is a nice and clean TIP142 emitter follower with TL431 voltage reference. The AC line is filtered (common and differential mode chokes).
The controller is a small Arduino Nano - it has enough I/O ports to control the DAC registers, select the input and output channels, control the LCD display, the IR remote control and the rotary encoder.
The firmware is based on Hifiduino, but it was completely rewritten and optimized. It has two display modes - a "normal", clutter free one, with essential information, and the full setup mode. The LCD backlight fades out after some time to a lower level and it fades in on user action.
The enclosure is a HiFi2000 Galaxy, very good quality. Front pannel milled by Schaeffer AG.
This is the best DAC I have ever heard, especially with the async I2S input.
It looks very nice set up.
Which is the best sound , through the Lundahls, or through the Mundorf or through the op amp. Do each have any particular 3D image or other attribute or downside.
This particular pcm1798 certainly won't beat a buffalo 😀 The good thing about it however was that I was able to build it by using only parts already in my drawers (and etching a few boards).
It's a dumb pcm2707 followed by a pcm1798. Power supplies are cap multipliers followed by regs for both analog (lm7812/7912) and digital supplies (reg101). The only original thing about it are the small class A buffers to assist the opamps in the I/V (the lower currents of the pcm1798 are here a blessing). From what I remember, it was suggested by jcx but I see it's been done here too so the inspiration could have come from either.
I'm still hesitating on how best link the earthed case and the circuit common. I need to test it for noise with either a simple gnd link or a groundloop breaker.
