Hello,
is it still possible to buy a phono stage and and a shunt regulator. If i ngo on Quanghao it tells me no carrier to Italy
also no carrier available to Netherlands... How is it possible to shop in your shop? Any trick can be used?
Hi Quang Hao,
I would like to buy 1set of the phono PCB and shunt power PCB to be shipped to Malaysia.
Thanks.
WR
Rick
Thanks.
WR
Rick
PCBs for the phono and, eventually, one shunt power please
Hello dear Quang Hao,
I would like to buy, from you, one phono PCB and, eventually, one shunt power PCB, to be shipped to Romania, Europe, please.
Thank you!
Warm regards,
Ion
Thank you!
Warm regards,
Ion
Phono boards
Guys have a good news ! I just got email from Quang Hao he is wiling to make a few PCB boards.I mentioned about others that are interested in boards.Hopefully he will do it for us !I'll keep you posted !
Guys have a good news ! I just got email from Quang Hao he is wiling to make a few PCB boards.I mentioned about others that are interested in boards.Hopefully he will do it for us !I'll keep you posted !![]()
hi!
ok, you can make it!
I can make pcb to all!
thank you very much!
quanghao
Hello Quanghao
I would like to enter the list for a ful set of PCBs (phono and power supply). Pls keep me posted
Regards to all
Regards to all
Hello Quanghao
Regards to all
Regards to all
I'm very interested in any PCB boards for the variations on the D3a and C3m and the new preamp and any masterfull powersupplies.
I can build it myself if I have a parts list and a well made PCB board or even just a list of parts (or buy parts markup 25 percent) and pictures (no insturections-unless really hard) of maybe 6 stages as you build so you can compare your progress to the original.
Please post me if boards are available!!!!!ASAP!
Does anyone know if this is in the works or should I proceed with trying to build a D3a or the C3M amp point to point with a lot of the values missing? I'd much rather have
a pcb with easier instructions due to language barrier.
Thanks 🙂
Mark
Thanks 🙂
Mark
Please advise how I should purchase the PHONO-ASH (Phono D3A) board and the SSHV power supply board to build this D3A phono stage amplifier.
Hi all!
many time i can not sell and produce it!
thanks
If you can open for me one GR in Diyaudio i will make it again!
Thank you very much!
quanghao
I have a mate [here in China] that has building custom Class A valve equipment [amps, pre-amps, etc] for >15 years.
He can do custom work[OTs, Chassis, PCBs, complete , and provide parts.
His last customer bought a 30W RMS Stereo Amp [Russian valves] with silver wire wound OTs!
Have photos on FLICKR and price list for Russian [and Chinese OEM] valves...........
Hello quanghao and all,
I just realised that 3 years have passed since I purchased the boards. I have assembled the shunt but even if I have all parts project stayed in a drawer for so long...
Now I have some time on my hands and am keen to finish. I would like to mount the tubes on the top plate, and all components below. Since I will use the Front pane Express I was wondering if Quanghao can post a mechanical drawing of the phono PCB. I tried to do measurements myself but somehow am not sure for 1mm or 2mm here and there.
So can we get the drawing of
1. All dimensions from the center of 1 of the mounting holes (which ever does not matter)
2. The distance of all mounting holes.
3. The distance of all middle points for the 4 D3a tubes.
Thank you in advance,
Pred
Pred
ok, i will sent to you when i finis it for you!
thanks
Hello when can I expect the drawings? I have done a large part and now want to do the metalwork.
Thank you in advance.
Next project ready with the D3a
Some months ago have found in my country the not-ready KIT by one guy. As in my stock are been many years ready a lot of stuff, like Altec Peerless 4722 step-up traformers, Cardas connectors, Jensen Capacitors and old USA resistors etc... i have decided to made this project ready for my Garrard 401. The results are very amazing and what is good--tubes are making more lively sound compared to transistor amplifiers. It also very good resolution in the sound. Best tube amplifier in this level! I am using end caps yet 0,22 uF. Think they are not enough. If I am comparing to high end transistor amplifier –there are more powerful sub- bass. It be very helpful, if somebody can tell , what upgrades are been as good step forward by this phono amplifier. Also what is small problem— slightly hearable hum in both channels. Maybe it is because I haven’t yet build shield . The transformers are separate for anode and filament voltage. There aren’t shield between primary and secondary windings. Maybe it is reason maybe not.
Please tell about your experiences with this amplifier.
Yes, the D3a is a very good tube, especially for phono. But because of the high amplification is is very sensitive for stray fields, and that is where the hum comes from in your build. You should think about building an external supply, and use shielded input wires.
Output cap should be minimum 1mF. RIAA caps and resistors should be matched as close as possible. And the Salas SSHV 2 is better than the first one you used.
But already in a simple version this is very good. BTW I found the attached circuit to be better, more linear and smaller resistor values in the RIAA for more dynamic sound. You can omit the Ecc288 Line output of course...
Have Fun!
Have Fun!
- More Vendors...
- Quanghao Audio Design
- OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli
