Studio Reference Amplifier
SR200
Hello to all,regarding bais setting there are a few ways to do this..1 via mv setting across emitter resistors,2 reading the volts over the tracking transistor,3 current idle draw with no signal or load..remove one of the supply fuses and place your meter
in current mode and adjust the bais pre-set to 100ma..
Amptech,
thanks ,i will try 2 & 3 way of measurement.because I've done the first way but have not been successful
thanks a lot
A super layout by John Bali
Here is my version with only a few small changes to Johns layout. For the second channel, I will adjust the position of the MJE yet, then it will be perfect.
Sound is good at bass and very clear in the middle and treble. But I have checked only at old car speakers for test. Amp comes immediately after the AX14 in the favorites list.
regards Olaf
