DAC-END R (ES9018) full assembled board - version 2
what jum you remove it ??
thanks
The image shows the jumper I removed. But removing it made things worse.
that is may be i wrong it!
the tranfomer with SPDF in put need one to GND,
I put it welded by hand.
there may be inadvertent, I did not check thoroughly.
thanks
and now you fix it ??
I soldered the jumper back and now it's OK, but sometimes there are still some instabilities. Nevertheless the day plays fine.
Hi Quanghao,
My version-1 DAC still needs the modifications to the shunt regulators, and I don't have the skills for such precise soldering.
So I would like to send the DAC to you in Vietnam. Could you please advise which address is correct -
- Dong Da District (I received the ver 1 DAC from this address)
or
- Ba Dinh District (I recieved the LL1684 PCB from this address)
or
- Hoang Mai District (as listed in the User Manual)
Thanks.
Hi Quanghao,
Thanks.
hi!
i have new address : Hoang Mai , please sen it to me hepl you!
please write the gift for me, and price under 30$
thanks
