Tea-bag I have added myself to the spreadsheet for 2 boards and 2 full kits.
Note I have already paid for the folded phono stuff so you need to paypal invoice me for the reflektor stuff only. you should have my email in previous PM.
Many thanks
Many thanks
Many thanks
Done.
Hi Tea-bag, I update the spreadsheet for my staff.
Please let me know if everything is clear and send me the paypal invoice.
Thanks and Regards,
Enrico
Thanks and Regards,
Enrico
Transformer size
Hi. The build guide recommends a 30va or higher 9v transformer. This is recommended even for small draw builds, like load consumptions of 15mA and 8mA? Would a 25va 9v do ok with these, or 30va is the hard minimum? Thanks
It will do if you will set 300mA CCS. You can use DO-41 1A diodes in that case as well. The 30VA general recommendation is to cover all modes with much ease. Both for low temperature and for minimal drop under load.
I have upgraded the R6 1K to a Vishay/Dale CMF55 .1% 25PPM to the resistor kits
It's a reasonable priced resistor with better specs than the MRS Beyershlag resistors used elsewhere, and Salas says this one counts.
The model # is CMF551K0000BEEB
9 More days left for GB. I will send out a private message explaining payment process and details on the minikits as well, over the next 4 days. I will be traveling on and off this weekend but will try to keep up with any private messages.
Thanks Turbon!
To the rest-
One week left for GB. I have started to send out private messages with details on GB. But essentially, I need your paypal email PM to me so I can send an invoice to you. All needs to be paid up by 7-20-14.
To the rest-
<SNIP>
... I focused on covering something the Bib was not aiming specifically at already. i.e. the sub 5V needs and around. It became even more persuasive an idea when I listened to Reflektor powering Subbu V3. A very good result.
I'm considering buying a few kits.
Besides:
1. The ability to go down to 1.2v
2. Lessened heatsink requirements (works with on-board sinks)
3. The ease of current & voltage setting
Are there other benefits of the Reflektor-D version over the standard BiB-style as a digital circuit regulator?
If this has already been covered in the Simplistic thread, please point me there, I didn't want to go fishing in that LONG thread without a guide.
TIA!
Greg in Mississippi
- Group Buys
- GB for Salas Reflektor-D Power Supply for Digital
