That's what I suspected, but I'm not enough of an EE to be certain.
Also thx on the clarification on the lowest output, I misunderstood that from the build guide.
I'll get some on order!
Again thanks!
Greg in Mississippi
Again thanks!
Greg in Mississippi
GB Ending
5 days left in GB, please make sure you are signed up, and have a PM to me with your paypal email address
I am considering one of these supplies to power a BeagleBone Black; assuming just powering the BBB and no USB peripherals, peak load is quoted as 460mA during boot up but at idle load can be closer 200mA (at 5V). As the Reflektor D is a shunt design and my understanding is that they deliver a constant current and 'burn' anything not used by the load and I'm wondering if this significantly variable load might give a problem though...
If I assume a shunt current of 75mA, added to the peak load of the BBB the total peak load will be circa 535mA @ 5V, which looks within the capability of the Reflektor D.
With the BBB at idle though the power supply will need to dissipate more watts (about 3-4 times as many) due to the lower draw of the BBB and, of course there will be other situations in between? I'm wondering if this might be too much for the devices?
Would a good compromise be to work on an expected load and accept a reduced shunt overhead during peak loads (such as at boot up)?
Or perhaps I am misunderstanding something?
Grateful for some enlightenment.
Ray
Ray
You can set for 500mA CCS to cover the initial peak by 40mA still functioning with no transient Vout droop and let idle at 300mA average spare. With 1.2R (2-3W) R1. Chunky idle bias brings more gm (transconductance) to M2. i.e. a good thing as long as dissipation is still logical. You use the BBB for a sonic app?
Thanks Salas.
I'm looking to use the BBB with the forthcoming Twisted Pear audio cape (Botic).
Also looking at a second Reflektor D for the Twisted Pear Buffalo III DAC, though as that has local shunt regulation modules I guess there will be only minor benefits over a conventional regulated supply.
Ray
Ray
Don't know, I have read anecdotal findings in the Bib thread that pre-reg still counts, but I don't have a buffalo.
Hello Guys,
I have genuine "Y" grade 2SK117's which is about 1.2-3.0 mA idss. Is there any post regarding to calculate component values according to my needs? I also think to use IRF630 instead of MTP3055.
P.S. Avoid IRF630 for lower than 5.5Vout due to its >double VGS, it will also curtail the open loop gain -3dB point and give sooner rising knee to Zo in the supersonic HF area.
Last two days to sign up! Group buy ends tomorrow night 7-20-14
Please PM me with your email address for paypal invoice, if you have not done so already.
Thanks, Tea
Thanks, Tea
Added 2 BIB BJT minikits to the spreadsheet assuming that it is for positive voltage. I am doubting because the headline says "- BJT" , but cannot imagine a negative voltage for digital circuits.
Jogi, only the kits for Reflektor-D are in blue in the spreadsheet.
The BIB kits will not work here.
Here is more detail on the kits
MiniKit BOM section. This links goes to full details of all the parts included in the kits and there respective positions on the board.
http://www.diyaudio.com/forums/blogs/tea-bag/741-salas-board-minikits-full-kits.html
- Group Buys
- GB for Salas Reflektor-D Power Supply for Digital
