Shigaclone MKII Black - The builders Thread
Right.
Take care on miniregs position too. small white square on minireg and pcb board.
For V2 you need an regulator capable to deliver at least continuous 100mA. For minireg dissipating 300mW is too much.
For V1 you need to take 150mA peaks due laser operation and auto-gain on CD-RW.
As you noticed, now Shiga MKII is able to read the most demanding CD-RW and scratched CD-R, but will eat a little more current than MKI.
Tibi
Cool thanks. I will report in a bit 🙂
In the meantime, I replaced C8 with my 10nF FT-3 and installed C11.
While there was improvement, I have to say that MK2 is less responsive to those changes than its predecessor. Granted MK2 sounded wonderful even without any of the mods. Perhaps it is the superior layout that already benefits the sound significantly, making all other changes less significant comparatively speaking.
Oh and trying to find what is going on with the slow TOC reading, I found in my post #7400 that I had the same problem with MK1 when I experimented with regs. I then solved it by isntalling a decoupling cap right on the entrance of the pcb. Perhaps it is because of my long PSU wiring. I will get to that eventually.
In the meantime, killing the LCD's backlight still makes a positive difference 🙂 I am rethinking about my capacitor timing layout again... I will post about it when I clear some details.
I just finished installing the miniregs. No technical problems at all.
The difference is quite audible. Mostly into spatial information and articulation in mids. I really liked how more secondary piano notes can now be clearly heard filling in between the main piano theme. I will have to wait a few hours before I can make more tests with more complex music, but overall it is a nice step up 🙂
Tibi you got any suggestions on what miniregs to use on V1 and V2? I think Erik vouched for the Teddys
Thank you, dimkasta !
Now give him 300 hours burn-in.
For V1 and V2 I would suggest Belesson super-regulators or new Burson.
Teddys may be a good choice as well, but not tested by me yet.
Tibi
Yes.
V1=V2=V3=V4=5V
Allowed voltage, for very good performance, is in 4.8 - 5.3V range.
I recall, V1 must me equal with V2, same for V3 and V4.
So, if you have a regulator V1 = 5.2V and V2 = 4.9V, than your Shiga MKII will not work. Keep |V1-V2| difference under 100mV for best performance.
Tibi
Hello Tibi,
So if I want to use the Belesson Super Regulators for V1, and V2, should I get the SPM Mini that's capable of 225ma, or the standard 500ma regulator? Then, I'll need a 10v tranfo, and rectifier? Which I can mount in the power supply, which I will make separate and connect with a shot umbilical. Is this all I'll need? Thank you very much.
Tony G.
OK there is definitely something wrong.
The bridge chip is running hot. There seems to be some random resets sometimes when the cd breaks, for example when hitting stop.
And after a while on some sacds it seems to be trying forever to read toc.
Any suggestions?
I will try to rebuild the PSU tomorrow with some not so low ESR caps, in case the FRs are creating any oscillations on the 7808, although I see it running only at ~40 degrees C.
For now the main suspect is the low amperage diodes (1N4007) I am currently using. Although they do not run warm.
Hello Tibi,
Tony G.
Go for standard + trafo 10Vac. + rectifier + filtercap min 3300uF. If you go for bridge rectification Shindengen are one the best.
Tibi
Any suggestions?
Please be more specific, what you have done to get such performance ? 😀
Tibi
Following modification address and improve laser operation of SFP101N-16P Sanyo cd mechanic.
Undoubtedly SFP101N-16P is a very good CD mechanic, but this can be improved further with a simple trick.
Modification is simple but require attention and a steady hand.
We are going to replace a ceramic X5R 100nF which decouple laser diode.
Tibi
Hi Tibi,
That sounds like a very nice modification. I will give this a try and post my results...I promise not to go for Duelund 😀
Thanks Again for the research.😉
Erik
