Slewmaster - CFA vs. VFA "Rumble"
Disabled Account
Joined 2012
Why so hard on the VFA ? The do REAL well on LF duty.
A VFA for your 20-100hz sub , and a pair of CFA's for the "soundstage".
OS
Cause I have a full range speaker system to use it on.... no separate sub is used/needed. But needs a lot of power/dynamics/head-room for the 2 - 15 inch bass speakers per channel.
On another system, I'll need a sub ( 2-18 inch drivers) and agree that a vfa will be good there.
THx-RNMarsh
Yeah I remember that from his book and I've considered it a few times. The trick is coming up with a system that will allow an I2C/SPI controlled pot to vary the bias without anything blowing up. I don't know if this will work, but I figured I'd give it a try and see.
Thanks OS, that seems fairly simple RE setting the CFA up for lower rails. With regards to the cap multiplier, I figure with it in place that it willdecrease the output swing capability of the amp by limiting the range the VAS can swing?
On the lower voltage CFA amp this isn't so much of a problem and I was perhaps thinking of regulating the rails for the small signal circuitry anyway.
CFA X 1.3
I don't recommend compensation between collectors and ground.
This method kill all the high frequencies.
Use the alternative methode ,CM1 CM2 .
PS CFA X 1.3 Gain=26
CFA-X Gain=30
Thimios.
:D I just want to know if VFA have high slew rate like CFA, is the sound same?
Back EMF at LF (and Z curves) affect CFA's differently than a VFA.
I'm simulating loudspeaker Z curves on these amps now...
Perhaps this is why Thimios favored them (VFA's) in his "bass" assessment.
As we are using the same OPS ... it has to be the FB . :confused:
As far as CFA's ... the current/voltage inputs are split on the "gnome" ,
the same 2 devices do BOTH on the CFA-X's . This also has effect.
OS
I got the JTK-CFA IPS working today. I tried the values in the schematic from post #2110. The lowest I could get the output was 8.1 mA. Something else needs to be changed as well to get to 4.5mA. I just changed back to the values Jason gave me and all is well. The 100R in R113 works. The heatsink is about as hot as I would expect. Probably want to go to 150R if you are using a thin sheet of aluminum.
I played it for a couple hours today. It sounds really good, especially considering it is an IPS that was designed to feed a couple MOSFETs.
Blessings, Terry
Present summary/"shootout"
I've changed and refined most of the original
amp designs (since the start of the thread).
The top 5 are ... (THD wise - below 1-5)
1-Wolverine
2-Spooky leach
3-Symasui
4-CFA-XH
5-Gnome
The fastest are...(slew)
1-CFA-XH
2-Gnome
3-Spooky ... the only VFA to even come close to CFA :D .
The cheapest .... $$$ :D
CFA-XH - @ 10-12$
The other 4 are <20$ IPS's.
These are the 5 final SOTA IPS's , the designs are about
as good as their topologies allow.
Of course , we could make a 40 device "instrumentation amp " ...
but would it be built. :confused:
OS
Blessings, Terry
The final VAS current on jason's board has 3 variables.
1- the VAS Re's
2- The resistors from base to rail on these devices, (R5/6) in the post.
3- the IP current. Jason's 500R VR1/3 need to go a little higher to get
<1.7ma at the IP pair. 1K trimmers would give you a range of .5ma -
(infinity - too much).
PS- I use a fixed resistor in series with the trimmer for safety and a limited
range of 3- 7ma VAS ! (470 -670R at CCS)
You should be able to get ANY VAS current with these changes.
OS
