Valve Itch phono
diyAudio Chief Moderator
Joined 2002
First I connected the step-up without the 47K load resistor, sounds OK both channels so I soldered the two 47K load resistors, connected and a big sound happened and no sound in both channels, once revised the first DN2450 was literally broken.....
I don't see the how you load the SUT has anything to do with the power side. Has not even to do with some plate, its from grid to ground. Is there any low Ohm path you can find between B+ rail and signal ground that changes with that SUT secondary load resistor?
Joined 2002
I remember that can't get 500V fuses and you recommend me to put two 250V 0,1A in series separate a couple of centimeters of course before the SSHV2, is OK?
They could be helpful, but if the event is so rapid and catastrophic I am afraid they will not be so fast to react. There is a weird reason to find why that happened first. Try the white+black+white/black on signal ground alternatively. Maybe something with the grounding created a mess.
Joined 2009
I connected wrong the Left channel.
