100W Ultimate Fidelity Amplifier
well I use a copy layout from mister Willy because my printer was not getting a correct size, and there are many options from Willy that are really good he did, I also have a few for myself for later here are some images :) I tend to make a collection of my favorite layouts on this diy forums also B500 is one of my favorites too :D
the layout I use is the one with TO-3 transistors but I have plans for TO-3P or TO-264 packing
Juan
Hi Juan,is any of these pcb already tested?
Only the one that mister Willy did, those other versions I have not tested yet but this one test it and all good here is the images, while I was listen to it I notice the main power transistors where getting a bit hotter so I thought because it does not have a zobel network then I add it a coil with a few turns with a 10 ohm 5W watts resistor and now is stable and nice and not and expert but I use what I learn from here :)
what slow me down on testing other boards is because I do not have to be honest good skills on etching boards I try the best I can and I love to see new designs here it does make me happy :D
Juan
  • AX-14.pdf
AX-11
If you gents could please share with me: What is the typical voltage gain of an AX11? also the typical bias?
p.s. I am planning on making bridged pairs with MJL output devices to handle bass/sub duty in a bi-amped system; so I would like to have an idea of how the gain will compare to the amps on top.
Thanks!
If the input filter is arranged as on the original ax-11 schematic, with the 2k2 resistor directly in series with the input cap and before the 22k in parallel with the 330p cap, this makes a divider with a ratio of about 0.909 ( 22k/2k2+22k ).
Then the gain of the amp itself is 1+22k/2k2, with the 22k being the feedback resistor value and the 2k2 being the feedback shunt resistor going to ground via the 100u cap. This makes for a gain of 1+10=11 for the loop and the input divider brings this down to 0.909x11=10 or 20db ( 20xlog(10) ).
This is reduced near each end of the audio band by the roll off attenuation.
hello i have made this AX-11 but output voltage is too high 190milli volts
what to do?
are those original Toshiba power transistors bro :confused:
the voltage is too high ? do you mean offset ? :confused:
maybe the bias you got running to hot try increase 3k3 use a 5K pot
temporary until you find the bias you want maybe 30mA I think mister Miles
already mention that :)
by the way the boards look nice man :)
Juan
Juan
Yes they are orginal Toshiba
Yes i am asking about offset voltage
And can i use 35-0-35 vac transformer
yes it is kind of high 10mV or less is better "if possible"
uhmmm the 35-0-35 can go too high after rec/filter = 52V more or less the toroid I have it give me about 53V
I'm not an expert but check resistors sometime I myself misplace them it happens
Juan
