UCD 25 watts to 1200 watts using 2 mosfets
You guys are throwing formulas around - show me where they come from please. As far as I know rms of power is simply sqrt(2)/2 or 0.707 times the peak power. Let's assume 1 kHz sine wave which is how power is specified as usually. Half bridge full bridge - why is that even a consideration for an amp that is making a sine wave audio signal. We are not talking about AC line power and power factors are we?
Here is the reference for RMS Power from TI for class D amps.
Using their equation on page 4 I get 8kW still.
http://www.ti.com/lit/an/slea047a/slea047a.pdf
Peak current is 180 volts /2 ohms = 90 amps. 90 amps x 0.707 = 63.6 amps. 63.6 amps ^2 x 2 ohms = 8kW.
180Vpeak would be the value in case of a full bridge or bridged operation of two half bridges.
From a single half bridge running with +/-90V you will only get 90Vpeak, because one end of the speaker is tied to the zero volts, means tied to the middle of the rails.
So you will just get half the current of your calculation, means 1/4 of your calculated power.
And even this is perfectly blue eyed, because you have to assume the sagging of the rails and additionally a few volts drop in the amp.
Hi Nano
greetings NICE WORK
warm regards
andrew lebon😎
Hi Andrew,
can i ask for PCB lay-out or any files for this amps below..
kindly send to my e.mail. danicaser@yahoo.com.ph
thanks...
can I use gapped ferrite core from PC PSU or another PSU (like Televison PSU), because I can't find gapped ferrite core in my place
thanks
Sorry for me answering that late.
Yes, you can use recycled gapped cores of PSU like EE-cores, EC-cores and the likes if you do not mind these might be more bulky than necessary.
If you give me the core-size available to you, and the supply voltage and operating frequency of your d-amp, I could give you a rough estimate of the windings required.
hi all a preview of up coming project . i got hold of some smd components 😀 i will use one pair of irfb 4227 and i want to use +/-72 volts . i wanted to drive the amp up to 1ohm load . any comments or ideas are highly acceptable and welcomed.
  • ucd discreet with prot smd.pdf
