Article - Sony VFETs part 1
Nice gesture the text "Thanks Papa!"
:forbiddn: Would have loved some small surface mounts though! :forbiddn:
I'm really thinking about branding that ...... Papa .......
Papa ...... © by Mighty ZM
:rofl:
Jensens are in! After two weeks at Dutch customs😡
Almost one monoblock ready... see pics.
I tested the regulators positive and negative, and they seem to work fine, input around 35V, output at 2 Amp: 22.7 Volts ...bit low. Can I change the 3x 9V1 zeners to get a bit higher voltage.
At power up, the voltage slowly increases in about 6 seconds to full voltage.
Hi sound, early in the morning? Je Je.
Watching for any good news here.
Have a nice weekend.
Hi Dady
Thanks i was just go sleep at the morning after all night party with the music.
Watch and progress everyday.
Thought about capacitors and resistors choice and wattage (biger)in signal path section....elna silmic, pio , teflon with naked z-foil , caddocs ?
http://www.vishaypg.com/docs/63140/var.pdf
Z-foil low noise Resistor
Maybe just diy with nice standard and tweek after ?
Mucho fiesta at the weekend too You !
Best regards
