F5 power amplifier
Yea, I saw that also. Looks like A-A type could be the minimum used, but not sure which orientation of the paper would be best. Though "Withstand 1K - 2K voltage" is impressive.
it has been confirmed that it works
maybe the added goo grease does the trick
but they also say just one little tiny 'something' jammed between device an heatsink, and it may all be over fast
other than that, I wonder if the very low insulation resistance could cause instability issues ?
I suspect that membrane might be more compliant than mica as the product is stated to 'flexible' - not sure. I usually scrape the heatsink stock I get from HS-USA with an old fashioned single edge razor blade, comes out close to a mirror surface. Never used any of the pieces from the forum store so I don't know how smooth they are.
Decision - Alu Oxide vs Mica pads
I purchased some Alu Oxide pads for the IRFP's
They are 2mm thick and have a thermal conductivity of 15.06 W/mK at 75°C
On the other hand Mica is 0.05 to 0.1mm thick (random) and has crappy thermal conductivity in the range of 0.5 W/mK
That means that if my Mica is 0.05mm then they are 40 times thinner but if they are 0.1mm they are only 20 times thinner.
One one hand they could be 50% worse than the AlO (if Mica is thick) or 50% better (if Mica is thin) in terms of thermal conductivity.
With the AlO there would be some risk of cracking them, but they look nice 🙂
Safe route (Mica) or AlO?
Alternative is to look for the best mica and shave it as thin as you can.
Mica quality varies, depending on the origin location.
Does require patience and a steady hand.
(by coincidence, I eyeballed a lot of mica at the geology faculty of the Amsterdam university, studied physical geography there)
