900W H-class PA Amp with Limiter
sir why i get -75 -55 0 +55 +75 with this psu does anything wrong with my trafo or any suggestion how to get like this schematic
Your measurements must be wrong.
i'll check again may be my tester got broken also, thanks
Ok. Maybe Iam to much ask n i know why im not get my answer. Thk. Iwill not ask again. Thk so much.
Are u sure ur trafo 45 42 0 42 45 ? Mybe 45 40 0 40 45.
sure my friend, first time i power up use 1 trafo 45 40 0 40 45 and now i use 2 trafo using 42V + 45V Vac
ok i see. so u are use 2 trafo each channel with secondary output 45 42 0 42 45. im rite? how much caps u use ? before connect to caps how much voltage u get?
i do this for testing Mr gantex
1. I use 1 transformer with 45 40 0 40 45 Vac with 10000/80V capasitor
2. i use 2 trafo with each secondary 42 0 42 and 45 0 45 but one of the diode got hot, i think this fail or one of my transformer broken (old transformer) with same 10000/80V capasitor
3. now i testing with toroid transformer 45 32 0 32 45 Vac with 8 6800/63V capasitor and 2 fake 35A fake motorola diode 😀 n the result is like this picture are this normal?
i'm finishing build H900 in december but i power up H900 this week 😀
i'm very courious to build this psu, may be my multimeter got broken too, cause several days ago i got wrong measurement
DC voltage = 1,414 * AC voltage (Diode bridge forward voltage don't count, no load condition).
If you have 45 32 0 32 45 trafo, you must have aprox. +63 +45 0 -45 -63 dc voltage. You can not change the physic of law 😀.
Please measure all voltage with ground as reference. If you measure DC voltage, set the multimeter for DC voltage and if you measure AC voltage, set the multimeter for AC voltage.
