Slewmaster - CFA vs. VFA "Rumble"
The jig is not intended to assist with preparing the heat sink, just with the assembly of the electronics. I would print another template and punch and drill it in a separate operation.
Sorry if I wasn't clear in my suggestion for making assembly easier. Seems I've had the opposite effect 🙁.
Terry,
I'm with you if I was going to do a drill jig I would use some sort of alignment pins and some drill bushings if I was going to do serial production or just set up a cnc program with a fixture.
Serial production is something totally different. Most of us will only need to prep a pair of heat sinks, so a paper template, a centre punch and a drill press will serve most quite nicely.
Now getting over 10 pieces makes doing something more elaborate reasonable.
This is probably just me, but if I am going to the trouble of drilling and tapping a jig for aligning the transistors, I would want to use that same jig for aligning the holes in my heatsink.
Thanks for the print template Jason. I'm going to make a template. I hate it when I get done and the outputs aren't exactly straight.
Blessings, Terry
Blessings, Terry
i use a 1/16 inch thick cardboard as drilling template using Jason's template printed on a bond paper and then pasted onto the thick board..
a pointed tool such as a pin to make indents on the cross-hairs, and then start drilling with a 1mm drill on the template thence to the heatsink, no need to drill all the way thru, just enough to make a deep indent...
you can then proceed to drill to desired hole diameter....
btw, this is also how i do 1 off board runs...and most of what i do are 1 offs..... 😀
:film:
Boys and girls here is Gnome V1.3!
To make you happy .... If you only have 1u for the servo caps (C10/11)
(you have some mounted below) , increase R26-27 to 1meg.
With 1meg/1uf = .37hz Fc , still good to go.
OS
:film:Gnome V1.3 first try.
Some resistors must be changed values ,my opinion.
OS, here you are the Boss.😉
Yes , maybe 680-820R for R13/16. With the new trimmers , R5/R10 ....
If you make the "safety" resistors small (R6/9 - 330R) , R5/10 should
give you a wide range of input device current allowing you to set your VAS
current perfectly ! 😎
Good to see the .5mv servo controlled DC value !
Also , with the trimmers , feel free to bias those VAS leds to taste
( 33k - 68k).
PS - I design at 70-85V , you build at 40-50V .... so , there will be some
variation (R11-12 -zener regs.)
Good work !!
OS
