Slewmaster - CFA vs. VFA "Rumble"
Will anyone create some boards we can purchase as a group buy for those of us who don't have the supplies or knowledge to produce or own boards. This looks like a great design that has so much capability and the variation in output power for the three designs should cover any need we may have. I know I would purchase some boards if offered.
Which tests do you want made? 🙂
[click on picture to see it larger]
THx-RNMarsh
This is why I do a V1.2 now.
Prototype ran first time (NAF) ... but we had to make sure.
Many current DIYA projects are having problems now (I WON'T elaborate).
PCB before the "bugs " are worked out :sad: .
I DON'T want this !! 😱 😱
The OPS is "good to go" - any takers for a batch o' chinese FR-4 ... I'll
give up the gerbers !
This IS the "cat's meow" for fickle builders who like to build a amp
a month to find the better "sound". you can make this into ANY 😱
DIYA class AB amp.
OS
Thanks Ostripper. I can wait for the details to be ironed out and the finished boards with the chosen input section. Another question is could these boards be used commercially without any patent problems if that could be arranged later on?
Final deal - (this weekend)
3-4 IPS's
1. NAF's "NADv1.2" with servo -
He says "wonderful" sound , 1mv offset, runs the OPS bias within a mV.\
I say "good to go" - tiny tweak to layout.
2."HB/wolverine" we KNOW this works - read the Badger thread. "war dog amp"
"good to go" 😀
3." VSSA variant" (I'm doing this now - multitasking) Very similar to the
NADv1.2 - 99.9% chance it will work just as well .... it is a far less
involved circuit - super simple .... sure bet !!
4. I might get to the "symasym" , it also - is one that I have already
built. Another sure bet. (this one is a great subwoofer IPS !!)
This can not beat the CFA's or HB/wolverine THD20 , but has the ONLY
10ppm 20HZ !
(below)
4 IPS's for many applications , all have different "personalities".
PS - NO infringements - my circuits are "bastardized" enough as not
to be like the others. Most designs are hybrids of several designs - ALL
fair game , no "prior art" 😀 I will integrate any good idea 🙂 .
OS
Am I correct to think that some of these are vfa and some are cfa implementations?
2 and 2 - just like the thread states "rumble"...
HB/wolverine and symasym are VFA.
NAD and "CFA-X" (below)are CFA.
CFA-X is dirt cheap ... amazing - 25ppm/90db PSRR /2mv offset - great CFA
"starter amp" 😀 .
ALL are 4-5ma VAS's , can be directly swapped out
to the OPS , might not even have to adjust the OP bias.
OS
No spray, clean the surface with paint thinner, just flip the screen and photocopying it on thin ex sticker paper
On shiny surface. Or use transparant photocopy mica/plastic.
Hi Naf sorry for this but i'm confused.
Can you tell me in which posts you have take files (pdf) for final version and what modification you have make?
Best regards.
Thimios.
Post 210 is Wolverine IPS board i'm not built it yet
Post 223 OPS board with RP (reverse pattern?)
I use CFA NAD-H for IPS (update on R17/R20 to 150ohm from 68ohm, R18 to 47k from 39k)
And my OPS board use early desain v1.0 dated 1/5/2014...have an orphan 10ohm resistor)
