F6 Amplifier
Thanks ZM
Your process is flawless. I always use this method except that I set the pot voltages to about .8V to start.
In this case, I started with 0and got to a max of .2
If the fets are fried. that sucks.
I'll swap out and add a led to try it out with IRFs.
BF: noted. Learn from mistakes
Don't know what went wrong. The other channel is fine.
well, BF and ZM were correct.
the semis have gone the way of the dodo. I would like members to observe a moment of silence in respect for these fine pieces of fet. If anybody can recommend a museum somewhere where I can donate, preferably next to a stuffed dodo.
I am in bereavement :crying::crying::crying:
I have a wierd thing with my F6 fuses... When I place ceramic tubed fuses in they burn every time I turn the amp off. Every time. Glass tubed fuses work fine. Both 1,25 A.
Can there be some variance in different production patchies? The ones in the local store seem to be the same touchy type.
If I used a 1,6 A fuse, would that possibly do harm to the amp before blowing out in the case of a problem..?
Sysmatics exactly as Nesson suggests. Dual mono 240V. Nothing extra.
Caps are 15 000uF and arranged as in sysmatics.
