Pumpkin Preamp - Perfect for F4
Easy fix. I actually had not turned the POTs down enough. All of the adjustment is at the very low range of the 5K POTs. I thought I had turned beyond the limit but I had not. Watching the V varying into the Darlington as I turned the POT clued me. All is good.
ZM,
While I have been able to eliminate the DC offset the attenuator still behaves erratically. I'm only persisting with the Twisted Pair attenuator because the I built the preamp case with the TP attenuator in place. The tests I've tried seem to show no fault with the volume control. Is it possible that there is another reason for the dips and pops?
Rick
Yes, set the offset as described to a very low level - millivolts - over a period of several hours. The Twisted Pair attenuator is a previous version but I believe they have similar specifications, this from their website;
"The kit's input impedance varies between 2.2K and 10K, with a fixed output impedance of 750R."
I know attenuator is working because I have 2 and they both behave normally in the other preamp I use.
I might try dropping the red value. I used the high 220k recommended.
Thanks for your help.
Thanks Zen, I have already put caps (2.2 uf) in and the resistors. There was a significant drop in DC with the resistors but not much more benefit with the caps. The pops and dips were still there with the caps so I took the caps back out now and left the resistors in.
I've got the same attenuator in my Aleph P 1.7 clone with no issues. I've swapped the relay boards and tried a different control board. Same results. Very frustrating because the sound is soooo good with the pair of F4 clones I've built.
Was the attenuator combined with the Aleph P at the output or input?
When it was at the input, the Aleph has as you know a very low input impedance.
You could imitate this with a 10k to the ground after the pot.
Would be interesting if the clicks disappear then.....
Good point generg. I have the attenuator at the output on the Aleph P1.7, as per Papa's instructions.
I'm hoping Twisted Pair can advise if there is a possible glitch in the programing but it seems unlikely.
I'm afraid I may just have to change the volume control to something else.
are you comparing it with Aleph P , with engaged input (gain , sort of ) attenuating , or with same disengaged ?
never mind - I just came back and re-read what you answered to Generg
unfortunately , I think - in that arrangement , you'll always hear ticks and pops - having that attenuator at input of preamp
with lesser input impedance (loading of attenuator shunted to gnd , in fact ) pops will be decreased
however , with caps in between , pops are having nothing with Pumpie itself
