DIY Good Class D amplifier
It works well with split supply in simulation,with very hard to drive mosfets,but i dont like the 8 A on d4 in my schematic,i would dissipate more power than anything
Can you see that slow start up edge on upper gate?
I use Multisim,result is same as in practice.I try to make better driver,but without results 😀
With resistor drive is much better,but dissipation is cca 6W (with max duty it's 12W!)
Check my new progress 🙂
Class D on +/-56V 500W SMPS working now,with feedback,offset 1,8mV 😉
Do any interested 😀
First pic. voltage measuring. (Left meter lies,chinese s*it) Both voltages is same.
Last pic. offset
Second pic. wave after totem pole
Third pic. is voltage at drains of fets.
Fourth pic. is voltage at SMPS transformer.
