F5 Turbo Builders Thread
Finally had time to finish my V2 today. I went from CLC to CRC without trying CLC. It is not the good time to mess with experiences with my first amp project, I went with a known path for the PSU. I also cascoded the jfets.
I'm trying to bias tonight. Everything looks good, no smoke, the heatsinks are warm. My issue is that I can't get the bias over 275 mV. I maxed out P1... Is it because I could have low Idss jfets? I don't know their value. Does the remedy is to increase the value of source resistors of jfets? If yes, which value? I have 1 kohm right now. I would like to go at least with a 350 mV bias.
Well, I was hoping that I can get some first hand info from you on the CLC filter. I constructed a CRCRC filter for my V3. See how it turns out.
Nice built!!
hehehe 🙂 2.2k resistors did the job. I still have room to bias higher. Heatsink are only at 40°C and mosfets at 50°C
Bulgin Illuminated Power Switch
Another noob planning a F5V3 Turbo build. I'd like to use one of those cool Bulgin ring illuminated power switches (MP0045/1E2). I understand that this switch on it's own will not stand up to the current inrush of these amps so a relay circuit is needed. My question is how to do this with off the shelf components/boards. I've seen pictures on this forum of a build that Scott (SRMcGee) did where he uses one of these switches along with the DIY store soft start PCB. I've searched for information on how this would work but have not found anything.
Switch:
MP0045/1D2BL012 Bulgin | Mouser
I have seen another relay start circuit from AMB Labs that looks like it will work but I'd rather not add another circuit if it's not necessary.
The ε24 Power Switch Driver Circuit
If I am able to use only the soft start board, where do I tap into the switched 12VDC needed to illuminate the switch.
I'd be grateful if anyone can clarify this for me. 😕
Switch:
I used the following switch in conjonction with the soft start circuit from DIY Audio store. You need a 24V switch. This was a direct fit. I wired the LED of the switch directly on the spot for the LED on the soft start circuit.
http://www.vandal-resistant-switch.com/pdf/vandal-resistant-switch.pdf
Thanks, Walter, that's what I needed to know. I don't think there's a published schematic on this circuit yet. Once I can see it it should help me understand the connection(s). The 24v part spec was something I didn't know so thanks for that.
Your build looks great, dig that switch.
F5V3 Turbo Monoblock is working
Many thanks to this forum and Nelson Pass.
I have done some measurement:
5,3Vrms in 4,1 ohm at 2,6A bias
orange: P3 optimised to minimum D4
green: P3 optimised to minimum D2
I am concerned about the PSU-Noise 50Hz, 100Hz and its harmonics.
On real speakers the PSU noise measured with my one ears is same as with my aleph X. BUT the aleph X has additional HF-noise. Both is not audible at the listing sosition, only about 10cm ears to speaker.
Trafo is 800VA 2x35V; 60mF-180mOhm-60mF; Rail is 46V at 2,16A bias
Any comments regarding the PSU-noise?
Switch:
Waterdog54:
Sorry for the sluggish response. Like petefrontiers, I used a switch purchased from Langir (sourced through a group buy I hosted early last year: http://www.diyaudio.com/forums/group-buys/231271-large-illuminated-anti-vandal-switch.html) and the diyaudio store's soft start board. The good news is that Langir's switch options are pretty good -- configuring exactly what you want was easy and their prices were far more reasonable than the alternatives. Unfortunately, Langir has a 20-unit minimum for special orders. If you have the time, consider hosting another switch group buy -- I ended up selling 35 out of the 40 switches I purchased in about 2 weeks (and kept 5 for myself).
Scott
Thanks Scott,
The pictures of your build are inspiring. Got a lot to learn but I'm sorting my way through it. I'll probably end up with Bulgin so I won't have to buy 20! But they are some $$$.
The switch is momentary, correct? The latching happens in the soft start relay circuit?
.........Any comments regarding the PSU-noise?
What does it measure?
Use a DMM to check the output DC offset using the 199.9mVdc and the output AC noise, using the 199.9mVac.
>1.0mVac = terrible.
<0.1mVac = very good.
Excellent is below the resolution of a 199.9mVac DVM.
What is unusual is the higher even harmonics of the mains frequency.
Usually 3rd dominates and the other odd are just higher than the adjacent even.
I wonder if this points to a particular wiring error?
Yesterday, I reached a bias of 0.450 V across the two 1 ohm resistors so 0.9A/device. I still have room to go higher but I need to get 5A fuses before. I have now 4A fuses installed and I'm near the limit of them. I will start testing with speakers and music with the actual bias.
