very good, this is also the same approach for kit 1? or will you post another diagram ?Hi,
This diagram practical,for 4CH-SDA(KIT-3) it can help faster without errors.
any nice tracking number for me 🙂 ?
I've received my amp/smps this morning.
Judging only by the look of the boards it seems really solid build. I'll mount the capacitor boards and then I'll get back on you to have some informations about the wiring.
I'm happy to have not asked for refund 😀
Nice to hear that things went well.. Remember to post a image or two 😀
Hi Maxidcx, This is your package started Yesterday.
In your case, yes, same connections becouse you want use two SDA-400 by one DPS-400 as 4Ch. all input board have same connections in all model.
I have some question via pm.
P.S. This input pcb allow simple connection without absolute noise or problem, consider that inputs scheme is a delicate parts of amplifiers. all is well tested,quiet and stable. I repeat it's not a super amps but mature delicius for amateurs. I want promote this Kit in France also. 🙂
Hi Roberto,
I have solder the capa psu board but I'm missing one resistor and one decoupling capacitor:
Received only 3 resistors and 19 capacitors
Alexandre
Alexandre
I'm Very happy you have received the pachage.Hi Roberto,
Alexandre
Ah...well, just change error instead of 10Pin connettors 😛
I send small package for this, no problem, I want you have same on PBTU-3. for now, you can solder any res 10K to 22K as pair. this need only for pull down the voltage, just if you disconnect power DC connectors. just for safety, no other.
Sorry for this error, but period we chose very poor for Kit.
I have found a resistor 15k in my toolbox same value as the one you send me but I have no substitute for the capacitor.
And don't worry it happens 😉
If I miss one decoupling capacitor can I still use use the amp or it's better to wait? At least I can try one amp 😀
Alexandre
Alexandre
Obvious you can try well.I have found a resistor 15k in my toolbox same value as the one you send me but I have no substitute for the capacitor.
Alexandre
warning on the polarity in all please.
Sync
a question , AP
Is there any way to sync your amp modules in a multi channel setup
Cheers ,
Rens
a question , AP
Cheers ,
Rens
Ok!
Btw I'm still trying to figure how you can win money selling this kit 200 euros considering all the bundle (amp/smps/psu/entry board) and the quality of the components... Pretty amazing!
You are right, ..I want demostrate that the opportunity offer by quantity well selected, and a good job, can offer high quality products,complete in all functions,as protection,relay gold contact,offset guard etc, is possible instead of a product with only smd parts without protections and without problem solved as audio response.Ok!
I hope this GB can help DIY also, when buy a simple smps, ask... it is for audio? or ..lamps 😀.
Hi,a question , AP
Cheers ,
Rens
I prefer that the stages have a very low EMI and excellent rejection instead of sync. Some have mounted everything on a piece of wood, such as demonstration of immunity to noise or frequency beats.
Regfards
Sorry , AP2 I ment Roberto
a question , AP
Cheers ,
Rens
Please explain
I want my multi channel amps working IN SYNC with the same carrier frequency to prevent any intermodulation distortion, especialy in stereo mode between the channels . My class D amp is sounding marvelous in 5.1 , but in stereo mode it's not good , the rest of my stuff is pretty good , and if I connect one of my other stereo amps ( class AB) it sounds perfect .
I am pretty sure the problem lies in the different carrier frequencies of my current ( Self oscillating pre filtered class D) amplifiers , so please answer my question .
Cheers ,
Rens
Regfards
Cheers ,
Rens
Some pictures:
And the rest of my setup for my active speaker:
Now I have to put all this sh** in a 43cm*43cm case 😀
Hi PandaZya,....amazing photos resolution!!
Thank for shared your products, I'm sure you are happy with Sound!
Roberto can you please tell me what is what on the sda-400 balanced/unbalanced connector because I want to connect my dac directly on the amp board. Can you please tell me where to connect for unbalanced setup and balanced.
Alexandre
Alexandre
Hi Rens,I want my multi channel amps working IN SYNC with the same carrier frequency to prevent any intermodulation distortion, especialy in stereo mode between the channels . My class D amp is sounding marvelous in 5.1 , but in stereo mode it's not good , the rest of my stuff is pretty good , and if I connect one of my other stereo amps ( class AB) it sounds perfect .
Cheers ,
Rens
I quite understand what you mean, It is no longer used the sync. a good project is taken care of in the choice of the stages that comprise it, it takes experience to "see" some things.
Even if I do not know your amp, I think I understand.
Try these amps if you can. while you listen, you do not think the class D.
Alexandre
Hi Alexander, If you can, use Flat cable & input board,
ALPS pot, put at the max (R=zero).
In the meantime, this is the connector on the SDA-400.
Hi Roberto can you confirmall the connections to be sure I'm doing it right for an unbalanced setup?
Oh and how do I connect the capacitor board?
- Vendor's Bazaar
- SDA-400 Professional multi-way
