diyAB Amp The "Honey Badger" build thread
Hi cod3gen,
are you using 4 output pairs?😀
What resistor value did you use for R27 ie 68 or 100R?
You don't need no 4-5 pairs.
Buy 3 pair MG9410/6330 ... use 80V rails , and the stock badger
is a 400W BEAST !
PS -I would also run the VAS with 56R (10ma CCS).
OS
Just to make sure I have understood this correctly - the value of R27 is 56R if you increase the output power of the amp. In "normal mode" the value is 68 -100R. Is this correct?
56R set the VAS CCS for 11ma ... this may make the EF2 OP stage less susceptible to "droop" with low Z loads or facilitate using lower Hfe outputs
(MJL21193/4 ). The bias trimmer should "range" all the below currents.
This will , however.. increase heat and change the bias setting of the Vbe.
It will not "increase power" by itself , just change the electrical characteristics of the VAS/CCS.
56R= 11ma 68=8.8 82= 7.5 100= 6.3
Schema below with V/I measured at 60V rails. 🙂
OS
OS not only are you a great amp designer but you’re willing to assist others.
Big thanks from all of us who appreciate your work!
I don't know about great ....
Doug Self ,Malcolm Hawksford .. that's great !
But .. when I started , Andy C. and others were very helpful indeed.
Bob Cordell still explains to us "unwashed masses" everyday in easy
to understand terminology.
We are indeed fortunate to have DIYA as a resource. 🙂
OS
Kudos!
Just want to jump in and 2nd that.
I finished my HB build about 8 months ago now but still follow this thread to see what others are up to. My Honeybadger gets used for several hours most days, often at a slightly obscene volume levels and for a wide variety of music from classical through to jazz, blues and rock. I gotta say it rocks! Brilliant clarity, low end grunt and that wonderful, airy soundstage. It never ceases to put a grin on my face! Kudos to Ostripper!🙂
Can someone confirm that 0V and IN on the lower right side of the board is my RCA input from pre-amp and OUTPUT and SPK/GND is the output for the speaker? I've gone through the build and setup of R17/R7/R30, everything looks correct, yet I only hear very faint sound from my speaker if I turn the pre-amp to nearly full volume.
Confirmed !
"everything looks correct" ? 7-8 V across R14 ? 0V at output ?
30mv (or close) between TP 1/2 (or...15mv between tp1/2 and 0V)?
Photo's + more details = more ideas to come to a resolution. 😀
OS
Confirmed !
OS
yes, yes, and yes..
please excuse my solution to not having the right size fuses, they are 4A 250V..
i've also checked for any shorting on Q13-21, all good. i have nylon bushings in the mail but that keratherm sheet is doing its job
Disconnect input .....
Touch "in" with your finger - is there loud hum ?
If you are using a large capacitor, is the jumper NEXT to C1 bridged ?
OS
I get some static and some hum if I touch the input. the jumper isn't bridged, so it looks like my cap isn't wired up!
can i hook this up and get going or will I need to go over all of the other trimmers again?
