VSSA Through-Hole-PCB build thread
I wanted to give an update on my amp. I had a problem with blowing fuses if I changed inputs while the amp was on. I also noticed a slight hum. I decided to revisit my grounding scheme. I built a ground loop breaker and then installed a star ground bolt and reworked all the ground wires to land there. No more issues now and it is completely hum free. I thought I should share since I was asked about the ground scheme earlier.
Now that both VSSA have had a chance to burn in they are basically identical in sound. Very, very articulate. I'm not sure it that is best for all recordings since it is so revealing, but string bass is stunning and acoustic guitar is in the room with you. Lovely amp, for sure.
Congratulations Terry!
Exactly the strings of the bass are very well revealed to my ears by both VSSA and XVSSA (details almost unknown to me before). Also electric guitar riffs are extremely well reproduced, and here is where I found the parallel film cap over feedback electrolytic proved crucial in XVSSA. Acoustic guitar passages are also a delight.
Enjoy your new builds!
Thanks for the photos, Terry. Just to make sure I understand the grounding, the bolt next to the ground loop bridge is isolated from the chassis, correct? Thanks.
